cosworth pistons
Genuine Cosworth YB 6.2:1
Compression Ratio Pistons
BRAND new set of pistons for a Cosworth YB engine. This pistons are now very very hard to get hold of, especially in a new un-used in original packaging.
These pistons will lower a standard engine's compression to 6.2:1 however the block can be decked to suit in order to make the compression ratio what ever you desire.
As previously stated these are new pistons with the following measurements:
cosworth recommended finished (honed) cylinder bore size: 90.810 - 90.820mm
compression ratio: 6.2:1
Quantity of 4
These are manufactured by Cosworth themselves, not copies.
The RRP of these pistons was 115+vat each (total for a set of 4 £540.50)
07710913091
£350 ono
Quantity of 4
07710913091
£350 ono
JK12
33
Apr 26, 2021 12:09 PM
cossie09
Oct 11, 2015 06:29 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
