4-layer steel head gasket
Hello!
First, sorry for my crapy English!
I bought a 4-layer steel head gasket from England.
I am unfortunately a bit unsure about the quality of this. I ask you here if you can see if you recognize it, or may speak on the quality, then it is from your home country.
I would be very grateful if you would help me with this, then it will sit in a Sierra Cosworth 4x4 -91 with about 500hp.
Regards! /Jonas
Regards! /Jonas
www.ajusa.com seem to be the company. There's a head gasket of that model on a Russian website I found on Google, http://translate.google.co.uk/transl...n%26safe%3Doff Which says it's an Ajusa head gasket.
Other than that, never heard of them.
its the gasket most big power cars use, very reliable.
most cossie tuners sell them including matt lewis
around Ł200 normally
Interesting! Is there any indication on Mountune gasket?
The only text that is on my gasket is: "AJUSA 178 TOP"
Can I trust this one, or should I use a GrA?
Regards/Jonas
you will have to ask someone who has a wrc mountune gasket to see if they have the same markings on them, they are probably made by a sub contracted company for mountune.
if it is a mountune gasket, it is the one to use!
also looks like a 4 layer cometic but i have a cometic one sitting here in front of me and it has no markings like that on it (or on its packet).
It had feelt good to know if there is at good gasket or not, so I dont need to worry about it anymore.
Regards/Jonas
Ajusa, can they might buy in Mountune gaskets and put his own name on them?
Their name can been writen on the gasket afterwards? Especially if they look exactly same?
Regards/Jonas
Regards/Jonas
Hello again!
I had a friend here for a little while ago. He has bought a 'real' WRC 4-layer steel gasket, and we compare my and his and we can not find any difference at all! Everything is the same, layout and thickness.
I still believe that Ajusa set its own name on the gaskets they buy, and which they then sell as 'real' WRC gaskets. Right?
Regards/Jonas
Regards/Jonas
RS & ST Parts Specialists
I personally do not think Ajusa is shit, but I want to hear others views and experiences.
Regards/Jonas
go ahead and use it
no its not a big deal, but why have an issue when it can be avoided?
if i had the choice i would rather not,replace cam belt, head gasket, head skim, ancillary gaskets, etc
just for the sake of using a better quality gasket to start with
im sure many peeps use the cometic without issue, but i chose not to use one because of the stories i heard
My opinion on the head gasket thing is that cometic and wrc are just as good as each other IF they are clamped down well enough.. i believe that most heads lift too much but with the wrc having 4 layers it disguises the fault.
Just my opinion.
I have always run cometic and will continue too.
Just my opinion.
I got lite info for me now abaout Ajusa gasket. I can't use it on my engine. I got O-ring round the cylinders sĺ i can only use Group A gasket.. :/
Well, se how it goes
Regards/Jonas
Regards/Jonas
