cossie head question(cam caps how much)
Old Oct 25, 2008 | 08:28 AM
jonesymk2's Avatar
jonesymk2
Default cossie head question(cam caps how much)
would a cossie head be any good without the cam caps or is it no good for anything without them
Old Oct 25, 2008 | 08:45 AM
cozmeister's Avatar
cozmeister
More boost Igor!
You can buy them, and you can buy the studs, would be a pain in the backside if any of the studs had been removed but sheared off
Old Oct 25, 2008 | 08:49 AM
jonesymk2's Avatar
jonesymk2
ok cheers mate
Old Oct 25, 2008 | 12:24 PM
jonesymk2's Avatar
jonesymk2
next question is how much will the caps and studs be
Old Oct 25, 2008 | 01:00 PM
xr4x4rs's Avatar
xr4x4rs
i think if you get different cam caps for the head not the originals you will have to have it lined bored so there all the same, bit like using big end caps on a block that has none
Old Oct 25, 2008 | 03:43 PM
jonesymk2's Avatar
jonesymk2
thought i might have to get something like that done but how much will caps be as if there to expensive i wont bother with the head im looking at
Old Oct 25, 2008 | 04:59 PM
jonesymk2's Avatar
jonesymk2
anybody else
Old Oct 25, 2008 | 05:01 PM
cossie daz's Avatar
cossie daz
i think i seen the studs on Graham Goode Racing's EBAY
Old Oct 25, 2008 | 05:13 PM
jonesymk2's Avatar
jonesymk2
yeh just found the studs but where can i get the caps from and how much roughly
Old Oct 25, 2008 | 05:26 PM
jonesymk2's Avatar
jonesymk2
bttt
Old Oct 25, 2008 | 07:15 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Burtonpower have them for 11.75 each for the front two, and 8.95 each for the others.
Old Oct 25, 2008 | 11:43 PM
jonesymk2's Avatar
jonesymk2
thats not to bad then cheers
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
shortie
Aug 19, 2015 01:01 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Roosie
Aug 13, 2015 07:40 PM
