5th injecter position (90 spec carrier)
oki doki, got a mf2 5th injecter system for my erst powered xr2. now i have a 90 spec rocker and charge carrier (obviously lol) and the 5th injecter came with an 80 spec carrrier, easy i thought, just put it on the 90 spec, well not so easy...
As you can see, try and put it eather side and it conflicts with the carrier mounts. has anyone else got one fitted on a 90 spec carrier? can you show me a pic? or do i have to use an 80 spec
cheers
cheers
i was hoping there was aqay round it as my 90 spec cover has jus been coated, spose ill hve to get the earlier rocker cover off me spare engine and send it off
I had one on a 90 spec charge carrier - will find a pic tomorrow, not got laptop with me
Mine had to go on the Right Hand Side of the carrier, below the bracket - putting it on the other side was a bit dangerous if i smashed the front end of the car in and knocked the end of the injector off
Only drawback is that it cant fuel that much extra compared to a big injector in ther CC pipe, ok if your not running massive boost.
cheers for that carlos just some people are to quick to shoot other people down in flames i was only giving the person who started the thread another option...
