Fuel pump rewire kit , high afr help?
Old Oct 24, 2008 | 05:43 PM
carlo's Avatar
carlo
Default Fuel pump rewire kit , high afr help?
As per previous post my car on load is running 13.4 afr , fuel pressure is 4 bar at idle.
I havent got the fuel pump rewire kit fitted yet but while on load fuel pressure is still ok on the gauge.
Does this mean that the original wiring is ok or could the prob be the because the rewire kit isnt fitted..
Old Oct 24, 2008 | 06:05 PM
glancy2081's Avatar
glancy2081
if the preasure aint dropping i dont think this will be the cause of the car running lean, sure i will be corrected if i am wrong
ps if you are checking it on andys rolling road you could check voltage at the pump when on boost
Old Oct 24, 2008 | 08:44 PM
carlo's Avatar
carlo
It wasnt on the rolling road it was tested out on the road with fuel pressure gauge & innotive.Its had new fuel pump 044,fuel filter,will need to see how it goees with the rewire kit & take it from there
Old Oct 24, 2008 | 09:15 PM
michael harbour's Avatar
michael harbour
you been out in it mate?
Old Oct 24, 2008 | 09:17 PM
scoooby slayer's Avatar
scoooby slayer
if fuel pressure doesnt drop then voltage hasnt dropped. iirc your head flows 28 % more than standard so getting loads more air than old engine.
Old Oct 24, 2008 | 09:18 PM
scoooby slayer
i wouldnt up fuel pressure either as it has to effect spray pattern of injectors.
Old Oct 24, 2008 | 09:26 PM
carlo's Avatar
carlo
No mate how does it feel i know you were test piolet
Old Oct 24, 2008 | 09:27 PM
carlo's Avatar
carlo
I wont up the fuel pressure anymore
Old Oct 24, 2008 | 09:28 PM
michael harbour
goes well. when you picking it up?
Old Oct 24, 2008 | 09:30 PM
carlo's Avatar
carlo
Just when its ok mate i would rather it was safe.im going on holiday 2 moro for a week so i have left it with ag to sort it out for me getting back
Old Oct 24, 2008 | 09:42 PM
Jay,'s Avatar
Jay,
Sponsor
carlo as said if the fuel pressure is ok then its a map issue iirc when phil bought a chip off karl moons ago phil emailed the datalog to karl to trim it might be worth a chat
Old Oct 24, 2008 | 09:53 PM
carlo's Avatar
carlo
Data log ? how do i do that mate? im on l6 if that makes any difference
Old Oct 24, 2008 | 10:21 PM
Jay,'s Avatar
Jay,
Sponsor
well andy's innovate will log all what goes on then just mail that file off
Old Oct 24, 2008 | 10:31 PM
carlo's Avatar
carlo
Im on the case jay
Old Oct 24, 2008 | 11:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
If fuel pressure is ok as the AFR falls then its not the pump filter or lines causing the issue.
Old Oct 24, 2008 | 11:46 PM
Karl's Avatar
Karl
Norris Motorsport
Carlo,
Did you check the AFR at say half throttle and 1 bar boost. It should have been around 12.5:1. As I've mentioned on your other post, if after you have re-wired the pump the engine is still running lean, then prime suspect is TPS sensor wired incorrectly.
Also make sure that you don't have ANY possible leaks on either the map sensor of fuel pressure reg lines. Don't for example have a dump valve T-pieced in to either the map sensor of fuel pressure regulator vac lines as this could easily cause the same problem.
Old Oct 25, 2008 | 08:33 AM
carlo's Avatar
carlo
Thanks karl i have forwarded all the info on
Old Oct 25, 2008 | 09:26 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Good luck wit it Carl, Do as the pro's have said, but also check the mounting of the fuel rail, I had the same prob a while back & it turned out to be the thread in the plenium that holds the rail on had gone so the pressure of the injectors etc was pushin the rail out, was no signs of leaks or anything & only happened when flat out !!
Karl did the MAP for mine in the same way as you want (Phil's old engine) & when we put Chip's Wideband on it, the fueling was SPOT on !! so trust his word, it WON'T be the MAP !!
jb
Old Oct 25, 2008 | 09:35 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Just to question the obvious, when you say that on boost the fuel pressure is ok, you mean that at 2 bar of boost you have 6 bar of pressure yes?
Old Oct 25, 2008 | 09:36 AM
carlo's Avatar
carlo
Thanks jb im going on holiday in a few hours & dont want to i would rather stay & get this car ok dying to get a shot its looking good whats happening with your car?
Old Oct 25, 2008 | 09:37 AM
carlo's Avatar
carlo
Chip that i dont knnow its not me thats working on the car but i presume it has , its only running 25psi at the moment.
Old Oct 25, 2008 | 09:39 AM
Chip's Avatar
Chip
Well it should go to 5.7 bar of fuel pressure when on full boost then.
If it doesnt its a fuel pump or wiring problem, if it does then that isnt your issue (although may still be worth upgrading anyway)
Old Oct 25, 2008 | 09:43 AM
carlo's Avatar
carlo
Thanks chip , the wiring will be getting fitted on monday
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
