Rivet Gun Help!
Old Oct 24, 2008 | 08:58 AM
Luca's Avatar
Luca
Lukesville
Default Rivet Gun Help!
Im needing to help the workshop department out at work, we have a carbonfibre frame in which needs a cable guide attaching, we have the relevent parts to fix but not a rivet gun with a slim nozzle.
If you see the guide tapers up around the hole which means the rivet gun nozzle sits pissed and not close enough to pull it straight.
Does anyone have or know where i can purchase a slim rivet nozzle ( or whatever there called)
Thanking you
Old Oct 24, 2008 | 09:06 AM
Twellsie's Avatar
Twellsie
are you after a manual one or a air one?
Old Oct 24, 2008 | 09:07 AM
Twellsie's Avatar
Twellsie
and what kind of rivet?
Old Oct 24, 2008 | 09:09 AM
Luca's Avatar
Luca
Lukesville
Manual one prefered but we do have an air one.
Have you a contact / different pieces to hand?
Old Oct 24, 2008 | 09:13 AM
Luca's Avatar
Luca
Lukesville
The rivet measures shaft into the frame 3.2mm and the shaft in which you grip is 2.1mm
Im a rivet virgin here
Old Oct 24, 2008 | 09:23 AM
Twellsie's Avatar
Twellsie
we have loads of differant types as we do aircraft stuff, i cant lend you one as they are not mine, but i can have a look and see what we have and point you in the right direction.
i presume the rivet is a regular "pop" rivet (not Avdell etc?)
Old Oct 24, 2008 | 09:41 AM
Twellsie's Avatar
Twellsie
i have just had a look at a few of ours and none of them seem that slim, another way around it is to get a small bit of bar with a hole drilled up the middle that you can slip over the rivet and providing the shank on the rivet is long enough, should still pull tight
Old Oct 24, 2008 | 10:16 AM
Luca's Avatar
Luca
Lukesville
Will try this route many thanks
Old Oct 24, 2008 | 10:19 AM
Luca's Avatar
Luca
Lukesville
Sorted works! cheers for that mate
Old Oct 24, 2008 | 10:48 AM
Twellsie's Avatar
Twellsie
no problem
3drRich
Sep 13, 2015 07:32 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Ryan
46
Nov 29, 2004 07:44 PM
