mechanical oil presure gauge
Old Oct 24, 2008 | 03:05 AM
Smartdj.'s Avatar
Smartdj.
Question mechanical oil presure gauge
well it 4am and no better time to find out how i fit my ford oil presure gause to my esrst im reallly confused and cant work out where to fit the little pipe to...does anyone have a diagram of fitting one???i want it fitted before i fire the cr up so any help would be amazing
Old Oct 24, 2008 | 07:39 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Think you need a little adapter that lets you T off where the oil pressure light switch is.
Like this: http://cgi.ebay.co.uk/ESCORT-MK1-MK2...d=p3286.c0.m14
Old Oct 24, 2008 | 07:56 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
what karl said,make sure u do all the fittings tight as and the pipe doesnt rub thru otherwise u will have a car coverd in oil
Old Oct 24, 2008 | 10:30 AM
Smartdj.'s Avatar
Smartdj.
ok wicked what about sandwich plates..i might run one of then with an oil cooler aswell while im there
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
