Running a wire from battery to interior?
Old Oct 22, 2008 | 03:52 PM
Squip's Avatar
Squip
Default Running a wire from battery to interior?
Hey guys.. just a quick question
Ive been trying to run a power wire straight from the battery to the glove box for ages in my Mk3 fiesta. Cannot seem to find a suitable way in
Any help much appreciated
Old Oct 22, 2008 | 03:54 PM
mk2rstaff's Avatar
mk2rstaff
must be a hole where the speedo and accelerator cable comes out mate, just a matter o following them to the bulk head and popping the wire through, whats it for, cant you just add a wire to the ignition mate get a pos from there?
Old Oct 23, 2008 | 11:43 AM
Squip's Avatar
Squip
its for a ridiculous horn i HAVE to get fitted.. theres no getting out of it either, dont ask
basically its a control box that has the 12v running into it, which needs to be located in the glove box, then 2 wires running to the horn which ideally needs to be under the bonnet, so i still need to find a way to run wire through.
I was thinking about drilling a hole and using a sliced grommet
Any comments or suggestions much appreciated
Old Oct 24, 2008 | 11:41 PM
alexno1dj's Avatar
alexno1dj
pull back the carpet and firewall in passenger footwell and there is one there, but best place is thru the bulkhead on drivers side, right in corner near bonnet hinge there is a big rubber grommet where wires already go thru, just poke a hole thru that and poke wire thru, shud appear in drivers side footwell when u have pushed enough wire thru.
3i Jim
Nov 20, 2015 05:12 AM
FordJonah
Aug 22, 2015 08:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
turbobill
Aug 1, 2015 08:55 PM
