Gartrac gearbox info please
Old Oct 22, 2008 | 10:12 AM
RWD Pete's Avatar
RWD Pete
Default Gartrac gearbox info please
Possibly going to buy a gartrac gearbox for my rwd saff later today, he says its a direct fit as it comes with all adapters etc.
How can i tell if its genuine or not? will it have a different casing?
cheers
Old Oct 22, 2008 | 10:33 AM
RWD Pete's Avatar
RWD Pete
anyone?
Old Oct 22, 2008 | 10:39 AM
Phil's Avatar
Phil
Jeebus
I didn't know Gartrac made gearboxes?
Old Oct 22, 2008 | 10:40 AM
It's Czech Mate's Avatar
It's Czech Mate
Maybe he means Getrag?
Old Oct 22, 2008 | 10:42 AM
RWD Pete's Avatar
RWD Pete
thats what it says in the description
Old Oct 22, 2008 | 10:46 AM
Phil's Avatar
Phil
Jeebus
If it was made by Gartrac I can see it being something along the lines of a Type 9 for early escorts or mk3/4's with their RWD conversions using a live axle. nI'm not sure why you would want to replace a T5 with one if that is the case.
If it made by Getrag then that would be a different matter...
You need to get more info before spending the money!
Old Oct 22, 2008 | 10:47 AM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
https://passionford.com/forum/showth...ghlight=getrag
Old Oct 22, 2008 | 10:48 AM
RWD Pete's Avatar
RWD Pete
he says its good for 500+bhp as he uses one on his tarmac rally car, i need a box as mine is shafted so i thought this would be a good upgrade, clearly not.
Old Oct 22, 2008 | 10:50 AM
Phil's Avatar
Phil
Jeebus
Sounds like Getrag rather than Gartrac then!
Old Oct 22, 2008 | 10:51 AM
RWD Pete's Avatar
RWD Pete
he wants Ł400 for it....
Old Oct 22, 2008 | 10:53 AM
Phil's Avatar
Phil
Jeebus
Give him a call and find out exactly what it is then some of the more knowledgeable people on here can give you some decent advise!
Old Oct 22, 2008 | 10:56 AM
RWD Pete's Avatar
RWD Pete
i have phoned him up he says its a gartrac box, he says its good for 500 bhp and it comes with bell housing etc. Thats all he can tell me about it so i thought i would ask on here for more info
Old Oct 22, 2008 | 11:00 AM
jon@work's Avatar
jon@work
this one ?
http://cgi.ebay.co.uk/COSWORTH-GARTR...QQcmdZViewItem
probably a getrag 265 from a jag
Old Oct 22, 2008 | 11:02 AM
RWD Pete's Avatar
RWD Pete
thats the one mate, are they any good if it is the jag box?
Old Oct 22, 2008 | 11:11 AM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
and a jag is worth how much ???
Old Oct 22, 2008 | 11:16 AM
RWD Pete's Avatar
RWD Pete
all i need to know is am i better off with a t5 or a 265
Old Oct 22, 2008 | 11:20 AM
RWD Pete's Avatar
RWD Pete
fitted to jag v12's and m535's etc so must be up to it
Old Oct 22, 2008 | 11:38 AM
jon@work's Avatar
jon@work
If it is a 265 with the adaptor plate, prop, and gear lever (ie the complete kit), then give it a go, but bear in mind that the box doesn't have a take-off for the speedo, so you'll need an aftermarket one.
Old Oct 22, 2008 | 01:09 PM
RWD Pete's Avatar
RWD Pete
The box was built by Gartrac engineering & was used in their rear wheel drive mk3/4 escorts usually powered by a 2.8 cologne engine. They are built to stand bhp in excess of 500. I have used one of these in my tarmac stage mk2 escort running a cosworth engine generating 470 bhp (after destroying 2 T5 boxes!) Very strong...comes complete with a cosworth bell housing & prop end so you can put it straight in. (you will have to have the gearbox end of the cossy prop swapped for the gartrac one...10 min job with correct tools)
mjonathan24
Oct 29, 2015 10:39 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
