anyone got a good pic of a 2wd rear 300mm disk conversion
Old Oct 21, 2008 | 10:25 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default anyone got a good pic of a 2wd rear 300mm disk conversion
Bought a 300mm rear disc conversion for 2wd cossie but the disc looks to far away when fitted. how think are the brackets and bells?
i think ive been sold the 4wd disc conversion whats the difference pics would be good please cheers
Old Oct 22, 2008 | 07:31 AM
saphycozzie-adz's Avatar
saphycozzie-adz
you got 4x4 calipers as 2wd ones wont fit.
Old Oct 22, 2008 | 07:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
measure the tickness of the disc
20mm means 4wd, 10mm means 2wd
Old Oct 22, 2008 | 07:39 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It's even more simple than that, if the disc is vented, it is for 4x4 calliper, if it is a solid disc, then it is for 2wd calliper .
Old Oct 22, 2008 | 07:43 AM
dojj's Avatar
dojj
i gave him more credit than that mike
if it's a solid disc, make sure you've put 2 wheel nuts on to hold it tight against the hub face as sometimes this is the root cause of the disc not sitting flush and striaght and looking miles off
Old Oct 22, 2008 | 08:01 AM
Roosie's Avatar
Roosie
its a solid 300mm disc yes
Old Oct 22, 2008 | 08:04 AM
Roosie's Avatar
Roosie
this the the new disc compares just didint know if the bells for 4wd not 2wd or something
Old Oct 22, 2008 | 06:27 PM
Roosie's Avatar
Roosie
btt
Old Oct 22, 2008 | 10:29 PM
dojj's Avatar
dojj
i'd say that looked like a 4wd bel to me as it seems to flat for the 2wd version
can you put up some side by side pcitures please? as in from the side?
Old Oct 23, 2008 | 06:02 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
I thought the rear discs were interchangable with 2wd and 4wd so the depth of the bell should be the same, the only differance being the solid and vented part and the caliper being differant, i could be talking total bollocks though.
Steve
With the disc bolted on, there is not physically enoguh stretch in the flexy pipe to reach the caliper, that's the first problem.
The second problem is the caliper if it were fitted onto the disc with pads in etc, is so far away from the brake mounting lugs that the spacer is about 3/4 to 1" too thin, doesn't bridge the gap between the two let alone bolt up.
The disc bells imo are wrong and need to be set in a LOT more.
Old Oct 23, 2008 | 06:37 AM
SS1's Avatar
SS1
the discs look spanky
but ive been told..and seen drilled discs get cracks in them
each to there own opinion.. but just grooved discs for me
Old Oct 23, 2008 | 06:48 AM
dojj's Avatar
dojj
Steve
on the 4wd versions, all the extra width is towards the outside of the disc and caliper, the inner mountings and cables and pipes all stay in the smae position so there is no need to change anything at the factory
you keep the same hub setup but change the width of the caliper to allow it to clamp onto a wider disc = less faffing about when you want to upgrade as everything is just bolt in and away you go direct from the parts bin
agree with the pipe needing to be longer to fit over the top
i'm just wondering if someones not just bolted either the wrong bell to it or even just bolted the bell on the wrong way around
Old Oct 23, 2008 | 06:51 AM
dojj's Avatar
dojj
on my mates porche turbo thing, he actually melted the discs between the holes
but this is going back a good few years now when he first got the turbo version (around the same time as the 355 rari's were out because he was getting it fixed to part chop it in so no pics )
Old Oct 23, 2008 | 07:10 AM
The bells are the problem as they don't sit in far enough.
Old Oct 23, 2008 | 07:22 AM
Mike Rainbird
Caraholic
Whose kit is it, as it is not one I have seen before?
Old Oct 23, 2008 | 05:46 PM
Roosie's Avatar
Roosie
not sure mikegot of ebay from someone who said they come of a 2wd
here side pic
Old Oct 23, 2008 | 05:53 PM
Moonstone Steve.
Thats no where near right m8, wrong bell end of.
Steve
Old Oct 23, 2008 | 05:57 PM
Roosie's Avatar
Roosie
Old Oct 23, 2008 | 06:12 PM
gibbo frst's Avatar
gibbo frst
looks the same as the kit on my 2wd saff same brackets too just mine aint polished and they fit fine...
not sure on make tho...
Old Oct 23, 2008 | 06:21 PM
Mike Rainbird
Caraholic
Bells and brackets look like the correct ones to me as well....
Old Oct 23, 2008 | 06:24 PM
Roosie's Avatar
Roosie
what kit is yours?
anyone got a pic of the bracket fitted
Old Oct 23, 2008 | 06:25 PM
Mike Rainbird
Caraholic
On my computer at work I think .
Old Oct 23, 2008 | 06:28 PM
Roosie's Avatar
Roosie
which side does the countersunk part of the bracket sit?
Old Oct 23, 2008 | 06:31 PM
dojj's Avatar
dojj
4wd bell
the vents on the 4wd disc would bring it into the correct position on the hub
Old Oct 23, 2008 | 06:57 PM
gibbo frst's Avatar
gibbo frst
not got any pics of mine as car has been away for 4 months....
ive seen others on 2wd the same as mine too..
Old Oct 25, 2008 | 10:52 AM
Roosie's Avatar
Roosie
ok guys they do actually fit but need bigger brake lines.
Im just wondering why 2 holes in the brackets have deep countersunk in them and what way do they face when on the car as i originally though they were for the lugs on the caliper to sit but when i bolt it up the caliper sits at too much of a angle and wheel wont turn when i have them facing the inside of car its ok but still aint got a idea on how they go?
Old Oct 25, 2008 | 10:57 AM
dojj's Avatar
dojj
they may be countersunk because the bolts were allen bolts, to sit flush and not get in the way
Old Oct 25, 2008 | 11:55 AM
Roosie's Avatar
Roosie
you are right lol
just figured out why its because the norml nut is so close to caliper you cant get a socket in it when it turns so need to use allen key bolts lol
markk
Dec 2, 2021 06:59 PM
155lee
Aug 14, 2015 11:21 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
