looking into bushes!
Old Oct 21, 2008 | 07:38 PM
paulhussein's Avatar
paulhussein
Wink looking into bushes!
Hi,
I need to replace the 'compliance bush' from the lower arms of the front suspension on my 2wd 89 sapphire.
It may be a good idea to upgrade to poly bushes at the same time. Whats the best set to get? and from where ?
Also, when I am on full lock, turning the wheels jump a little because I think the suspension is lowered and the camber is out. Can I ill two bird with one stone and replace the bushes and somehow adjust this camber issue ?
I would be grateful for any advice.
Thanks
Paul
Old Oct 22, 2008 | 09:31 PM
The camber is set by the distance between the wheel and the body, fixed at the top but determined by the length of the track control arm at the bottom, you can get in situ adjustable arms, but a bit pricey.
As to the poly bushes there are many makes, I have used superflex/powewrflex/deflex/flowflex(was deflex) and super pro who make these for superflex.
I have found no difference other than price, and have been using them years, normally get superflex from chris witter.
Old Oct 27, 2008 | 02:37 PM
paulhussein
Wink
thanks
Old Oct 27, 2008 | 06:50 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
And I'm selling a full set of Floflex polys
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
