Any washing machine engineers about?
Hi all
I've got a zanussi zwf12070s washing machine, i've noticed the last coupleof times i've used it has stopped running and the green start/pause light has started flashing. Pressing the start button just starts the programme again, and it will run for about 15 mins until it stops again.
I've tried a service wash incase it is gummed up with crap, and all the lights went off on the front of it and it just died. I switched the power off on the wall, turned it back on and the green start light was just flashing again. Pressing it restarted the program again.
Any ideas of what is wrong with it? (apart from its fucked
Only had it since april!
Thanks
rich
)Only had it since april!
Thanks
rich
Think i may have found the fault - It plugs in behind the machine, and there is a fused switch for it on the wall above the worktop. I just pressed it and it made one hell of a buzz inside! Think it could be the switch that is fooked! I have plugged it in to a different socket to see what happens....
Rich
Rich
big_Rad
Sep 15, 2017 09:36 AM
