gt 2860rs turbo
Old Oct 21, 2008 | 02:30 PM
t16coupe's Avatar
t16coupe
Default gt 2860rs turbo
hi all i have never used gt series turbos before and do i have to use a oil restrictor with them thanks
Old Oct 21, 2008 | 04:05 PM
Red16's Avatar
Red16
You will need some kind of oil restrictor fitted, unless the turbo housing has an inbuilt one, my mates Pulsar gt3071r has one integrated in the turbo casing.
Old Oct 21, 2008 | 06:42 PM
crazycage's Avatar
crazycage
how do you no if its built in ?? ive got a gt series turbo and the oil restrictor is just a fitting with a 1mm hole in it . why do you need to restrict it anyway
Old Oct 21, 2008 | 09:09 PM
t16coupe's Avatar
t16coupe
i have been told the oil pressure on rover t16 engines is to high and needs a restrictor
Old Apr 30, 2016 | 04:28 PM
Rsturbo519's Avatar
Rsturbo519
Hi crazy cage can hoping for your help here. When you ran a gt turbo on your cvh what restrictor size did you use?
I have just fitted a gt28rs and don't want to starv it off oil. Turbo dynamics said to use a 1mm restrictor without even asking what my oil pressure was. As you know cvh only has about 3 bar hot under full load. So do you even need one?? Only concern is cold start up
Old May 1, 2016 | 01:24 PM
crazycage's Avatar
crazycage
I ran a 1mm restrictor in mine was fine for years
Old May 1, 2016 | 02:04 PM
charliecosworth's Avatar
charliecosworth
MG Maestro turbo 437
same turbo here 1mm fitted 2 years ago running fine
Old May 1, 2016 | 05:07 PM
Rsturbo519's Avatar
Rsturbo519
On a cvh guys yes?
Old May 1, 2016 | 05:19 PM
Rsturbo519's Avatar
Rsturbo519
Thanks for reply. Did you see what pressure the turbo was getting with a 1mm restrictor?
Old May 1, 2016 | 09:05 PM
charliecosworth
Am not sure but it smoked without it fitted, they have roller bearing or something so don't need much oil
Old May 1, 2016 | 10:38 PM
nigel b's Avatar
nigel b
my turbo has upto 75psi through it
-4 feed pipe
Old May 1, 2016 | 11:11 PM
stevieturbo's Avatar
stevieturbo
C**t
And how many people are going to be able to fit a pressure gauge, AFTER the restrictor which is built into the oil inlet on the turbo core ?
None.
BB turbos do not need a lot of oil.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
