Any cologne v6 experts around ?
Old Oct 21, 2008 | 01:42 PM
Kverna's Avatar
Kverna
Virgin-popper
Default Any cologne v6 experts around ?
Hi.
I'm planning a new project, and was thinking of using a 2.9L v6 engine from sierra/scorpio etc, with a explorer 4.0 crank.
Now, does anyone know what kind of rpm's I could run on stock rods and pistons, or where I can get lightend and stronger rods/pistons.
Anders
Old Oct 21, 2008 | 01:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
much easier to just fit the 24V engine from a granada or twin turbo the normal 2.9
you are limited to around 6k rpm in the 12V form and about 6500 in the 24V form
the 4.0 won't give you 4.0 as you need to use some other mods to get it all working right, not too sure as it's been a while since it was discussed by someone, as in a good few years ago
if i can dig up the info i will do so, but it's a lot of wor for not a lot more power
Old Oct 21, 2008 | 03:03 PM
Kverna's Avatar
Kverna
Virgin-popper
I don't want the 24V
And I know it doesn't give you 4.0L, but around the 3,4/3.5L mark. Wich is just where I want to be
Thanks for the help
Old Apr 10, 2013 | 10:27 PM
Breeck's Avatar
Breeck
Hello everybody! So, did somebody tried to set the crankshaft from 4.0 into 2.9 block? I really need to know is it fits correctly and nothing interfere for its rotation?
Old Apr 10, 2013 | 11:03 PM
dojj's Avatar
dojj
You need the 4.0 engine from what I can remember
I think they did some more work on this over on fordpower.co.uk
Old Apr 10, 2013 | 11:17 PM
Breeck's Avatar
Breeck
Question
it's some wrong link... "worddictionary.com.au" is opened when I click on it.
Dojj, do You know anything or anyone who drop 4.0 crank into 2.9 block? I can't just swap 4.0, so i'm searching other ways.
Old Apr 11, 2013 | 05:51 AM
stucapri2.9iTT's Avatar
stucapri2.9iTT
http://www.fordpower.org.uk/
as dojj said, best asking o fordpower
stu
Old Apr 11, 2013 | 09:47 PM
Breeck's Avatar
Breeck
I asked and found the answer by myself.
4.0 crankshaft is really fits to 2.9 block. I found man who put 4.0 crank into 2.9 Ford Scorpio block and made 3.3 turbo Ford Taunus
http://www.drive2.ru/cars/ford/taunu...52798531/#post
Old Apr 13, 2013 | 12:36 AM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Make sure you leave the dipstick out if you do fit the 4.0 crank in a 2.9 bottom end, there isn't enough room for it. The crank will catch it and rip it to shreds. Dave Ward (Sparkplug) on the XROC bulletin board and XR4 Register site has the conversion done, it make it 3.7 litres but he has an Eaton supercharger as well. His dipstick does not live fitted, he has a dummy handle to plug the tube.
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
4bturbo
Jan 16, 2015 12:30 PM
21
Sep 4, 2004 09:27 PM
