Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
wierd noises after cambelt on 1.8 zetec
Old Oct 19, 2008 | 10:38 PM
punto_td's Avatar
punto_td
Default wierd noises after cambelt on 1.8 zetec
i changed the cambelt on my 1.8 zetec earlier, all seemed to be ok until i started it and it now sounds like a diesel and whines loudly. what have i done wrong?
i marked the cams and crankshaft before, and they still all line up perfect.
the car also drives perfect and revs up fine, sounds terriable though, the belt isnt too tight and has got fair amount of slack in it.
http://www.youtube.com/watch?v=s3hkTEQT8Io
Old Oct 19, 2008 | 10:48 PM
babscossie's Avatar
babscossie
sounds like a diesel??????? maybe cam timing out.
whinning?? cambelt adjusted too tight
Old Oct 19, 2008 | 11:25 PM
punto_td's Avatar
punto_td
im pretty sure the whining isnt the belt being too tight, but i will do it again to tomorrow and see, fingers crossed.
Old Oct 21, 2008 | 09:06 PM
punto_td's Avatar
punto_td
right its nothing to do with the cambelt it self, i checked the tension and its fine, so started it up without the alternator belt on, and it sounds fine, no knocking, no whining, sounds good, but when i put it back on it knocks and whines again.
so something to do with which runs on the alt belt, any ideas? i really need to get this sorted the car is sold and needs to be collected but i need to fix it first, only thing i could possibly say is the belt looks a bit jumpy, he belt it self seems ok, worn but wouldn make a tap sound, but the belt seems to wobble about a bit, tensioner feels ok.
Old Oct 23, 2008 | 04:55 PM
punto_td's Avatar
punto_td
its the alternator i think..... taken it off and it makes a chugging sound when you spin it.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
gingeRS
17
Oct 2, 2015 09:42 AM
mondeomark
Sep 28, 2015 06:28 AM
