cvh or zetec?
Old Oct 19, 2008 | 12:30 AM
alby1ltr's Avatar
alby1ltr
Default cvh or zetec?
wats the easyest conversion for my hcs fiesta out of the cvh and zetec??
also is there any links to a conversion guide for any of these swaps??
thanx
Old Oct 19, 2008 | 05:12 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
a cvh is best as you can get them with a carb as for the zetec every one needs a wiring loom fitted and fuel pump ecu ect ect
depending on what cvh you use its a strate forward swap if you get the cvh out of thr fiesta turbo it will bolt strate up just rember to get the shafts breaks ect ect but that also needs a wiring in
if you get the cvh out of a fiesta mk2 xr2 or a carbed cvh of some sort you can use the fiesta turbo top mount and will bolt strate up
as for conversion guide a hanes manual has got very good instructiona in removing an engine
as for putting it back in just do the same in reverse
hope this helps
Old Oct 19, 2008 | 10:01 AM
alby1ltr's Avatar
alby1ltr
thanx buddy, wats the cvh like to wire up from a hcs?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
