drivetrain issue
Old Oct 18, 2008 | 10:23 AM
Lars_Ferm's Avatar
Lars_Ferm
Default drivetrain issue
I dont really know if i can explain this in english? But after the gearbox were the propshaft is devided before the support rubber and bearing.There is a rubber thingy that is suppose to go under the (dont know its name) that u use to tighten the prpshafts whit,but mine is missing(the rubber part) and i cant get them tight,is there anywere u can get them?
Old Oct 18, 2008 | 01:47 PM
Arne's Avatar
Arne
Forklar det på svensk då. Tenker du på festet under girkassen? Eller den hardy koblingen mellom mellomakslingen og girkassen?
Old Oct 18, 2008 | 03:29 PM
Lars_Ferm's Avatar
Lars_Ferm
Nej de är i skarven på kardan,efter hardy skivan och innan stödlagret..där är kardan delad och de är splines som man för in.Över splinesen sitter en mutter/hylsa som gängas på den främre kardan i den hylsa dvs på kardan ska de sitta ett gummi som klämmer imot kardan sen.
Old Oct 18, 2008 | 04:20 PM
booner999's Avatar
booner999
wtf ^
Old Oct 18, 2008 | 04:35 PM
Lars_Ferm's Avatar
Lars_Ferm
Originally Posted by booner999
wtf ^
Do u know the answer the question? ahh....ok
Old Oct 18, 2008 | 05:10 PM
booner999's Avatar
booner999
Old Oct 18, 2008 | 08:55 PM
THE RADMAN's Avatar
THE RADMAN
what he said
Old Oct 18, 2008 | 09:56 PM
Kelv's Avatar
Kelv
Almost there!
Lars, did Arne give you an answer?
have you solved the problem mate?
Old Oct 18, 2008 | 11:48 PM
JHS's Avatar
JHS
Doesnt sound like it. Im still a little confused regarding what part he needs, but Ive gathered its for the propshaft. Im guessing something to do with the middle "joint" on it?
Has anyone got a picture of a complete propshaft? Maybe he can point out what hes looking for...
Old Oct 18, 2008 | 11:58 PM
Kelv's Avatar
Kelv
Almost there!
i havent here, but i can photo the bits on monday if weve had no luck by then!
only 2 parts i can think of is the big rubber donut, or the bearing that mounts to the floor.
ie - this one
Old Oct 19, 2008 | 12:08 AM
babscossie's Avatar
babscossie
Or is he on about the doughnut??
Old Oct 19, 2008 | 12:11 AM
Kelv's Avatar
Kelv
Almost there!
im thinking it could be mate.
as he does mention its before the support bearing, so it doesnt leave much else to be the issue.
Old Oct 19, 2008 | 07:49 AM
Lars_Ferm's Avatar
Lars_Ferm
Yes its between the support bearing and the gearbox,there u can split the propshaft in 2 and adjust it in lenght etc.they are put together when u push the prop that comes from the back of the car rear diff etc inside the little prop from the gearbox,and over the prop goes some sort om nut that makes it tight IF u have a rubber gadget inside that makes it tight against the front prop.Its the rubber i need a got the nut and props.I have no problem whit english but all the mekanical words I hope u understand what i mean.
Old Oct 19, 2008 | 08:37 AM
Lars_Ferm's Avatar
Lars_Ferm
Old Oct 19, 2008 | 10:19 AM
Lars_Ferm's Avatar
Lars_Ferm
The nut on the prop,under that there is a rubber "gizzmo" thats makes it tight.thats what im looking for
Old Oct 19, 2008 | 10:29 AM
Kelv's Avatar
Kelv
Almost there!
i get what you mean mate.
ive got to nip into ford tomorrow, ill ask if its a part they keep and report back to you
Old Oct 19, 2008 | 11:45 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
That's service I tell ya^
Old Oct 19, 2008 | 12:10 PM
Lars_Ferm's Avatar
Lars_Ferm
Thats great thanks alot,here ford dont even got a picture of props and all parts,u have to buy a complete prop
If it comes complete whit the nut thats ok to.
Old Oct 19, 2008 | 12:53 PM
Kelv's Avatar
Kelv
Almost there!
ill see what Roger (my parts man at our local branch) can find out for me.
hopefully theres better options than having to buy the prop complete
Old Oct 19, 2008 | 05:57 PM
Lars_Ferm's Avatar
Lars_Ferm
Very nice of u,keep me updated.Dont think it will b easy to find.
Old Oct 19, 2008 | 07:38 PM
JHS's Avatar
JHS
If Ford dont do spares for these, maybe you can try someone like GKN Driveline. They do driveshafts, propshafts etc
Old Oct 21, 2008 | 04:42 PM
Lars_Ferm's Avatar
Lars_Ferm
BUMP!
Old Oct 25, 2008 | 05:50 PM
Lars_Ferm's Avatar
Lars_Ferm
anyone know where i can get one?
Old Nov 7, 2008 | 04:56 PM
Lars_Ferm's Avatar
Lars_Ferm
I really need one!
Old Nov 7, 2008 | 06:41 PM
grcossie's Avatar
grcossie
GKN have them, it`s the firm ho called unicardang earlier, in Norway
Old Nov 7, 2008 | 07:21 PM
JHS's Avatar
JHS
Yes, like I said before
Link:
http://www.gknservice.se/gkn-ids-sca.../locations.jsp
Old Nov 7, 2008 | 08:19 PM
Lars_Ferm's Avatar
Lars_Ferm
Originally Posted by JHS
Ahh my bad i didnt se that,il give them a call.Thanks
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
