The reason why im asking is cause my car used to have an after market air con system fitted and my car still has the air con pump fitted. Im gonna take it off tomorrow and fit the original pas pump and brackets tomorrow. I will have to see if i can get hold of 1 from a local motor factors tomorrow.
And they work loose all the time, then the metal PAS hose comes into contact with your cambelt... lovely. Luckily I smelled the burning rubber in time. Granted, I had been ignoring the squeaking belt for a week or so
