P100 questions
reet im loving the idea of a pick up daily but also drifty. and found p100's rwd pickups.
now got a few questions tho
they look like sierras from the front, do sierra bumpers/parts fit
are they easy enough to do engine swaps on.
parts easy enough to find?
just got an idea, pref on the cheap but a pick up
matt black
slammened
locking diff
around 200bhp so not to bad on fuel but enough power
deep/wide alloys
matt black
slammened
locking diff
deep/wide alloys
NO idea about the body parts, bumper etc but would have thought sierra ones would fit on front, the only thing to watch with alloys is the odd 5 stud pcd pattern as this is not std ford pattern, it's the same as some other makes, VW I think but not sure, just know it's not ford 5 stud.
wheel wise your limited if you use the original axle as they are 160 pcd which is the same as the transit and not much else unfortualy. the front half is sierra so all the body panels are the same and so is the interior, hope this info helps
