Plenum
Old Oct 16, 2008 | 09:23 AM
declan morris's Avatar
declan morris
Default Plenum
Does anyone have a pic of a plenum on a 2wd saph. There is a pipe missing from mine and its just sucking air in which is making rev to 2000 rpm and when i put my finger on the hole where tha pipe is meant to be it idles like new. So i need a pic of plenum and all pipeing if anyone has it. Cheers
Old Oct 16, 2008 | 11:09 AM
stevecossy's Avatar
stevecossy
Think 1 goes to map sensor then 1 to fuel press reg and 1 to ya dump valve, so follow pipes from these and see where they lead.
Hope its not ya map or reg pipes not on as that can fuck ya car up.
Good luck cheers steve
Old Oct 17, 2008 | 08:25 AM
declan morris
Thanks Steve, ill check all theses.
Cheers.
Old Oct 18, 2008 | 02:48 PM
Nearest front stud to dump valve(atmo or recirc), middle one to MAP sensor, this has two 90 degree bends a the bottom so that fuel vapour can't run in, rearmost stub to fuel pressure regulator, this is how mine is anyway.
Old Oct 19, 2008 | 02:53 PM
declan morris
Cheers folks
timsrs
22
Sep 24, 2015 08:14 PM
muffster
13
Sep 3, 2015 09:40 PM
Russ Hill
Aug 31, 2015 06:44 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 20, 2015 09:21 PM
