Losing oil, help!
Old Oct 15, 2008 | 10:36 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Losing oil, help!
Quick question, the crank case pressure is building up and blowing oil from the sump(its had a new one to try solve this but still does it now and its properly sealed when it goes back on), now what would cause this? the oil cap is coming off, but its not coming off with high pressure, and when you take it off, it still runs! Oil pissed out the d/v when driving and dropping down to 3rd from 4th....
Piston rings gone?
Old Oct 15, 2008 | 10:42 PM
lead_foot's Avatar
lead_foot
is awesome
Excessive crank case pressure is normally rings. Oil pissing out the D/V is normally turbo seals on the compressor side or maybe the oil is coming from the rocker cover to turbo inlet pipe (if its still connected)?
Old Oct 15, 2008 | 10:45 PM
Charlie Chalk
Unknown.
Defo coming out of the sump, can it see when the engine was running on a ramp, hence why it got changed, but its still coming from it
The oil coming from the d/v wasn't excessing, but was mentioned so just wondered.
Old Oct 15, 2008 | 10:48 PM
lead_foot's Avatar
lead_foot
is awesome
Does you sump use a gasket then? I just used sealant on my sump on my SR20 (S14).
What do you mean about the oil cap? The engine should still run when it is off.
Old Oct 15, 2008 | 11:07 PM
Charlie Chalk
Unknown.
CVH, not SR20... Its not mine, its a friends erst.
I always thought the engines meant to die down when cap comes off??
brand new sump gasket, and sealer used.
Old Oct 15, 2008 | 11:52 PM
rst230bhp's Avatar
rst230bhp
Mine does it creates an air leak, mine used to blow the oil cap off i bought a new cap and a bailey breather never done it since
Old Oct 16, 2008 | 01:32 AM
Rs-Simon's Avatar
Rs-Simon
I thought if the rings were knackerd it would smoke, I would check the breather.
Generally when the oil cap comes off it will die, if its MFI. Mines been coverted
to EFI and will run fine without the cap.
Old Oct 16, 2008 | 01:57 AM
Charlie Chalk
Unknown.
Its MFi yeah, have checked the breather but can't find nothing, and all the pipes are clean
Puzzled!
Old Oct 16, 2008 | 03:00 AM
Rs-Simon's Avatar
Rs-Simon
Only other things that can cause the pressure. Head gasket, turbo oil seals and valve stem seals.
Old Oct 16, 2008 | 10:14 PM
Charlie Chalk
Unknown.
Cheers mate
Old Oct 16, 2008 | 11:17 PM
gary scott's Avatar
gary scott
Might be a long shot but on series 2's they have an oil return drain bolted to the block next to the main cap. This helps drop the oil further into the sump. Now (ive seen this happen) if you put a new sump on which isnt a S2 item (non turbo ones dont have the hole in the baffle plate) then the baffle blocks this pipe up and dont let the oil drain quickly enough into the sump from the turbo and will cause the symptons you state.
But in all honesty its probably rings!
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
