Your help, braided lines and unions
Old Oct 15, 2008 | 09:11 PM
coswurv's Avatar
coswurv
Default Your help, braided lines and unions
right this is for my project in the resto section, i need to come off the banjo fitting of the cossie fuel filter, into some braided fuel hose then onto my 2wd fuel rail, what sizes etc do i need and where is the best place to get it all from ? how is the best way of doing it ?
Old Oct 15, 2008 | 09:36 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
http://stores.ebay.co.uk/autofitting...Q3amesstQQtZkm
Seem to have all thats needed i think m8.
Steve
Old Oct 15, 2008 | 10:56 PM
coswurv's Avatar
coswurv
cheers steve, anyone else want to shed some light on what bits or even sizes i might need, i understand i will have to weld a union in the fuel rail to connect to ?
Old Oct 15, 2008 | 11:39 PM
Diablo's Avatar
Diablo
I am about to do the same. This is the knowledge I have gleaned so far:
The fuel filter will require M14x1.5 fittings at either end. On the assumption that you are using -6 hose, you will need banjo fittings that can connect to that size of hose. Then just run the hose to your fitting on the fuel rail, which should be silver soldered to the rail. If you want to keep costs under control, you may decide to just use hose finishers (jubilee clip type) for the return.
I hope that goes some way to answering your question.
Best of luck.
Old Oct 16, 2008 | 07:47 PM
coswurv's Avatar
coswurv
Best of luck.
cheers mate that is exactly what i was thinking, i thought of blanking the normal inlet to the fuel rail off by cutting it off and welding a little blanking plate over the hole, then i assume i will open one end of the fuel rail up and weld a threaded union into it to be able to connect the braided line fitting to ? as for the return i will use the same hose for looks and just jubilee clip the ends as there not under that much pressure i dont think.
muzzman1
Sep 30, 2015 08:59 PM
