S2 Doesnt Boost Properly When Warm(help!!!!!!!)
Old Oct 14, 2008 | 01:58 PM
rs_turbo_lad's Avatar
rs_turbo_lad
Default S2 Doesnt Boost Properly When Warm(help!!!!!!!)
Awrite guy got a s2 here
spec-
10 psi
bleed valve [think its maybe standard actuator
full ss
supposedly chipped
air filter
standard intercooler
rite heres the prob whn i 1st start it up in the morning when cold its boost's fine but 5 mins later whn its warm it doesnt want to boost and wont and struggles to go anywhere past 4000-5000revs feels more like 1psi boost
any ideas help!!!!!!!!!!!!!!!!!!!
Old Oct 14, 2008 | 07:02 PM
bigryrs's Avatar
bigryrs
RSHoleinator
spec-
10 psi
full ss
supposedly chipped
air filter
rite heres the prob whn i 1st start it up in the morning its boost's fine but 5 mins later whn its warm its doesnt want to boost and wont and struggles to go anywhere past 4000-5000revs
dizzy cap and rotor arm try that mate
Old Oct 15, 2008 | 11:16 AM
Korda's Avatar
Korda
cheak plugs and leads cheak all hoses for leaks
Old Oct 15, 2008 | 05:28 PM
rs_turbo_lad
Default boost
ok bud gonna giv it a good check over at weekend
cheers
Old Oct 16, 2008 | 02:13 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
mine is identical bud, when its cold it flies but when it gets warmer it feels like an XR3i
gonna check mine over for those parts - let me know how you get on
Old Oct 16, 2008 | 03:36 PM
studabear's Avatar
studabear
another thought, have the emmisions checked out, if its running very weak when warm this could be causing your problems, when its cold it will have a richer mixture
Old Oct 16, 2008 | 05:35 PM
rs_turbo_lad
Default boost
yes no problem, i will do, yeah mine feels like xr3i aswell its annoying me.was gonna try a front mount on mine to see if that would cure it but prob not,let u know
Old Oct 16, 2008 | 05:37 PM
rs_turbo_lad
Default boost
ok bud, gonna giv the dizzy and plugs etc ,leads rotar arm ,then if not cured i will prob see if emissions will get it sorted cheers
Old Oct 20, 2008 | 02:14 PM
Zetec_mk4_XR3i
i changed dizzy cap and rotar arm......seemed to help it for about 15 mins (longer than usual) but now back to normal plugs next i think!
Old Oct 20, 2008 | 02:47 PM
RSTurboSI's Avatar
RSTurboSI
Question -
If it was spark plugs which is a main part for SPARK ignition how would this effect when warm? Unless there not working which means a miss fire and no spark = to not running. how can it change or diffa when warm. So to answer that it wouldnt start or run if there not working correctly.
My first option would be to get it checked out on a comp. This would show the problem for a sake of 50pounds.
So it boost's fine untill warm. I wouldnt say its a boost problem as such. HTleads wont be ur problem nor ur plugs. If it was ur dissy cap then it wouldnt boost whats so ever, boost leaks = no boost and emmisions is ur fueling which is no relevence to your boost but can effect the timming and running of the engine.
Anyone can say, man try thus but i would take it to an expert who knows whats wrong as no offence ment to anyone on here but my advice is to take it to be tested as it could be anything.
Old Nov 29, 2008 | 03:02 PM
Zetec_mk4_XR3i
alright mate, i think i have solved mine, changed the throttle position sensor and now mine is boostin a lot harder - worth a try
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
ajamesc
Sep 8, 2015 06:51 PM
