Injector Banks
Old Oct 13, 2008 | 06:32 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default Injector Banks
my cars up and running but im a bit confused with the injector banks
my ecu is a semie sinquentiol firing so it fires 2 injectors at a time ive got the left 2injectors as bank A and the right 2 injectors as bank B it idals but when revs it couthes and bangs can some one advise me please
Old Oct 13, 2008 | 06:44 PM
clarke5700's Avatar
clarke5700
pleaseeeeeeeeeeeeeeeee amy one
Old Oct 13, 2008 | 08:17 PM
PGT's Avatar
PGT
would help if you said what car / engine / ecu / injectors and what you've just doen to get it "up and running"
Old Oct 13, 2008 | 08:24 PM
clarke5700's Avatar
clarke5700
2.1 zetec turbo msv3 ecu
and its a mk2 fiesta
Old Oct 13, 2008 | 08:32 PM
Garage19's Avatar
Garage19
http://www.extraefi.co.uk/Drawings/P...om_VR_Hall.pdf
Old Oct 13, 2008 | 08:34 PM
clarke5700's Avatar
clarke5700
so the way i have wired it up is right then? any idears on my air temp sensor?
Old Oct 13, 2008 | 08:49 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It probably pops and bangs because its not mapped!
Old Oct 13, 2008 | 08:50 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
.. but I would run 1+4 and 2+3 for the injector pairing.
Old Oct 13, 2008 | 08:53 PM
Garage19's Avatar
Garage19
Me to.
Clarke have you tried reading the megasquirt manual?
Its online and should give you all the answers you need.
You need to use easytherm to configure an S19 file that you then load onto your ecu. This should get your ecu reading the right temps.
Old Oct 13, 2008 | 08:54 PM
rst in breaking's Avatar
rst in breaking
this is how mine was run clarke
Old Oct 13, 2008 | 10:54 PM
clarke5700's Avatar
clarke5700
Originally Posted by Garage19
Me to.
thats where i got stuck i cant make a s19 file ive got my 3 resistances at 3 different temps entered them and got stuck ive read the mega manual a few times about this area but still im unable to work it out hence i asked on hear
Old Oct 13, 2008 | 11:45 PM
PGT's Avatar
PGT
with MS it doesn't matter which injector you connect together since they all fire at the same time. the phrase "semi sequential" is a misnomer since they are just batch fired and the fact that there are two injector firing circuits is simply for load sharing.
if you can't make an s19 file you can't use MS! mind you setting up MS is a significant undertaking and not easy as is often made out - very interesting though. you'll find it much easier if you get a stimulator to play with it first
Old Oct 14, 2008 | 07:29 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Correction: they CAN fire all at the same time, they can also ALTERNATE. Sometimes you have to run them alternating, depending on the size of the injector. I tend to run anything I do as two squirts + alternating. That then gives you similar duty cycles as if you were running fully sequential.
The two circuits are not for load sharing, although that is a byproduct. The purpose is for the above functionality.
Old Oct 14, 2008 | 08:54 AM
PGT's Avatar
PGT
yes my error (it was 12.45am!) but the essence of my point remains: whatever you do with MS in terms of injector firing, if they all fire the same number of times per engine cycle, changing which pairs of injectors that clarke connects in parallel will not cure his problem!
Old Oct 14, 2008 | 09:03 AM
Garage19's Avatar
Garage19
Clarke, i'll try and find/write you a quick guide to loading your S19 onto your MS.
As said before, best thing to do is get the car in a state ready to map, supply some grub eg takeaway pizza and have a PF night of mapping with the usual suspects. I'm sure we can get it up and running nicely.
Old Oct 14, 2008 | 05:25 PM
clarke5700's Avatar
clarke5700
sounds like a plan mate lol ive got the car to idal now in fluters now and then but it does run its my gfs bday coming up soon so ill have to put it off a few weeks then ill get some cash 2gever and arange a night how much will you want for fuel?
Old Oct 14, 2008 | 05:57 PM
rst in breaking
il get a trailer if you want clarke and we'll get it up there one week end, but will need to be back before dark as no rear lights
Old Oct 14, 2008 | 07:43 PM
clarke5700's Avatar
clarke5700
ill sort the lights. what ones dont you have? lol sounds like a plan
Old Oct 14, 2008 | 07:47 PM
Garage19's Avatar
Garage19
Clarke,
Have you got a wideband? Has the car got any ticket/tax?
No need to bring it to me. Just arrange an eve with the east london crew, chip, jay etc and i'll pop down too on the bike.
Old Oct 14, 2008 | 07:49 PM
rst in breaking
sounds good.
Clarke, the have mo rear light, fog lights, left indicator makes central locking lock/unlock
Old Oct 14, 2008 | 07:52 PM
clarke5700's Avatar
clarke5700
Clarke,
ive got a wideband fitted to the car its taxed and tested (till the end of the mounth) but im not insured as of yet. gota sort out my gfs b-day present first
Old Oct 14, 2008 | 07:57 PM
Jay,'s Avatar
Jay,
Sponsor
Clarke,
im up for this ive always enjoyed mapping ms so count me in as part of the crew doug
Old Oct 14, 2008 | 08:02 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Committee calibration!!!!
Old Oct 14, 2008 | 08:05 PM
Garage19's Avatar
Garage19
That way there is never just one tit to blame if it nukes its self.
Only joking clarke!
You coming?
Old Oct 14, 2008 | 08:21 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No i'm sure you guys are more than capable
Old Oct 14, 2008 | 08:23 PM
Jay,'s Avatar
Jay,
Sponsor
oh come on it normally turns out to be a good event/meet happy occasion and opefully a car mapped
Old Oct 14, 2008 | 11:40 PM
clarke5700's Avatar
clarke5700
this sounds like a fun night do you all wanna cram in the fez tho lol wud b funny to see
Old Oct 15, 2008 | 05:57 AM
Jay,'s Avatar
Jay,
Sponsor
itll be a grin mate
Old Oct 15, 2008 | 10:08 AM
clarke5700's Avatar
clarke5700
Originally Posted by Jay.
itll be a grin mate
Old Oct 15, 2008 | 10:15 AM
Jay,'s Avatar
Jay,
Sponsor
you already know chip doug is a tall stocky lad im also 6.2 19 stone so i think we will fit in
Old Oct 15, 2008 | 10:17 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I'm 6'1" and 23 stone so no chance
Old Oct 15, 2008 | 10:22 AM
Jay,'s Avatar
Jay,
Sponsor
shit i bet one of us can fit in the boot and make sure the lamba probe stays in the pipe and imagine what load we would create up hill
Old Oct 15, 2008 | 03:51 PM
rst in breaking
sounds like you'll need to weld the shocks to cope with these in the car clarke lol
Old Oct 15, 2008 | 03:53 PM
Jay,'s Avatar
Jay,
Sponsor
ur getting strapped to the roof rack as our private mapping road patrol spotter
Old Oct 15, 2008 | 04:06 PM
rst in breaking
lol, ill just sit out the sunroof, i done this in xrt_si's cossie with its previous owner when it come on boost at 30psi, couldnt get back in though
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
