dreaded rust,look
Old Oct 12, 2008 | 10:34 PM
col cos1's Avatar
col cos1
Default dreaded rust,look
what would i do about this?
have it cut out and completly replaced?
Old Oct 12, 2008 | 10:36 PM
Lee Reynolds's Avatar
Lee Reynolds
yes
Old Oct 12, 2008 | 10:38 PM
col cos1's Avatar
col cos1
how does this part come then?
strut top and inner wing combined
Old Oct 12, 2008 | 10:39 PM
Lee Reynolds
It may not need a lot mate. You wont know the extent till you strip it back. But around that area needs to be spot on obviously!
Old Oct 12, 2008 | 10:40 PM
J1mbo's Avatar
J1mbo
B1mbo
get it sanded to metal and see how bad it is then its only a case of a lick of spray in the best case
Old Oct 12, 2008 | 10:43 PM
Paul_RS's Avatar
Paul_RS
A skilled welder can plate that and make it look like its never been touched
cossie604's Avatar
cossie604
Time to join all the other 3dr owners on here.......ie time to break her
Get the list up so I can get first dibs on stuff now
Seriously though, yeah cut out whats required and weld in new. At least the repair can easily be hidden there.
Old Oct 12, 2008 | 11:01 PM
col cos1's Avatar
col cos1
cheers but do you reckon a decent plate will do that?
i know it cant be seen wel from pics,think il get the header tank out and take the wheels and stru off during the winter and sand it back see how bad it really is
as a whole for 21y old its not that bad,its not seen a spray booth in over 10years and sat in a driveway unused for 5years i cant complain
Old Oct 12, 2008 | 11:06 PM
xr_craig's Avatar
xr_craig
Strip that back and shot blast it mate, you may be suprised. Might just be how the pic looks but it just looks like the sealer has cracked with age and held water. You may find it looks worse than it is.
Old Oct 12, 2008 | 11:08 PM
louie1's Avatar
louie1
hi there, have not long ago cut the turret out of my 4wd saph as the header tank hole had gone rusty.
i did think of putting a plate over the top, but i removed the turret instead and glad i did, as the rust had got between the panels.
covering it up will only hide it for a while maybe months,hope this helps
Old Oct 12, 2008 | 11:10 PM
col cos1's Avatar
col cos1
ok cheers il hav a proper look over the winter
think il look out for a cheap if any left gls/lx sierra to take bits off as a mate needs rear chassis legs aswell
Old Oct 12, 2008 | 11:16 PM
thebigyin's Avatar
thebigyin
double skinned round there,grind it back and see the extent,as above not difficult to repair for anyone with decent welding skills
Old Oct 12, 2008 | 11:17 PM
louie1's Avatar
louie1
you only need to remove the spot welds and the turret comes out a treat, clean it up and replace then its as good as new, would not advise a quick cover up.
Old Oct 12, 2008 | 11:28 PM
AlexF's Avatar
AlexF
doesnt look too serious to me - but you never know.
get it sorted before it gets worse.
Old Oct 13, 2008 | 07:17 AM
coco16i's Avatar
coco16i
There were a couple of brand new complete inner wings for sale on the bay recently, not that expensive either IIRC, 130 quid i think.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
