what would make a cam rattle?
Old Nov 12, 2004 | 03:39 PM
james_birch's Avatar
james_birch
Default what would make a cam rattle?
just had a high lift cam fitted ...was fine driving all the way home!
parked up for about 20mins engine off! then got back in drove to get some new tyres and it was rattling like foook! any ideas?
Old Nov 12, 2004 | 04:43 PM
nthorpey's Avatar
nthorpey
i believe you are supposed to run in a new cam, as it will need to work harden and normally an oil change should be done. What sort of rattle is it? Engine speed etc would probably need to here it to say what it is?
Old Nov 12, 2004 | 04:55 PM
james_birch
was ran in! oil change was done!
its a rattle...like tappets! got a feeling it just needs to settle down a bit!
Old Nov 12, 2004 | 05:44 PM
Rallyesport's Avatar
Rallyesport
The cam and all the new bits (if you purchased a kit) should be thoroughly smeared in with a special cam lub. When you fire up the engine, the revs shall be kept at 2500 for 20 min.
Old Nov 12, 2004 | 06:00 PM
james_birch
was fitted by a company! one off here! been trying to get hold of them but no answer as yet!
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
rog
Sep 4, 2015 07:24 AM
