alternator touching rad hose
Old Oct 12, 2008 | 05:22 PM
rudkinrst's Avatar
rudkinrst
Default alternator touching rad hose
hi, just wonderig if anyone has had a problem with this before. when releasing the clutch the engine is moving alot and is making the alternator touch and were through the bottom radiator hose.
cheers
chris
Old Oct 12, 2008 | 07:11 PM
studabear's Avatar
studabear
Sounds like u need to have your engine/gearbox mountings checked
Old Oct 12, 2008 | 07:53 PM
obrutsr09's Avatar
obrutsr09
Had this problum on mine, fitted vibra technics engine mounts and go shorter belt from motor factors
Old Oct 12, 2008 | 08:13 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
same as mate!!just bort new mounts and a shorter belt.then i put a strong cable tie around the hose and pulled it away slightly
Old Oct 12, 2008 | 08:37 PM
G420 DEL's Avatar
G420 DEL
same as above, without the vibra mounts
Old Oct 13, 2008 | 10:47 AM
RSandy's Avatar
RSandy
i had this problem, and resulted in a headgasket popping!
gearbox mount snapped, engine kicked, alternator pulley chewed straight thru the samco, coolant poured out, engine overheated before i knew what was happening, and headgasket failed.
worth sorting sooner rather than later, 1 simple rubber mount cost me a fairbit of cash, new hose, new HG, head skim, plenty of hours labour etc
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
Russ Payne
Sep 25, 2015 08:29 PM
