alternator touching rad hose
hi, just wonderig if anyone has had a problem with this before. when releasing the clutch the engine is moving alot and is making the alternator touch and were through the bottom radiator hose.
cheers
chris
cheers
chris
G911 TTA
i had this problem, and resulted in a headgasket popping!
gearbox mount snapped, engine kicked, alternator pulley chewed straight thru the samco, coolant poured out, engine overheated before i knew what was happening, and headgasket failed.
worth sorting sooner rather than later, 1 simple rubber mount cost me a fairbit of cash, new hose, new HG, head skim, plenty of hours labour etc
rsguy
44
29-09-2015 03:29 PM
Russ Payne
25-09-2015 08:29 PM
