st170 turbo
Old Oct 12, 2008 | 08:15 AM
crazycage's Avatar
crazycage
Default st170 turbo
been looking at oil coolers but don't no much about them ! ive seen them with a 80 deg stat but don't no what size cooler to get any suggestions ?? how about a 13 row ??
Old Oct 12, 2008 | 10:41 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Could possibly do with a slightly higher rated oilstat to keep the oil temp up around 95.
Depends where you're putting it, how much airflow it'll see etc.
I'm having to do a new oil cooler setup on mine at the moment...
Thinkauto and Webster Race Engineering are good sources for parts
Old Oct 12, 2008 | 04:54 PM
simon170's Avatar
simon170
Bear in mind that the 170 has a laminova as standard.
Old Oct 12, 2008 | 04:58 PM
Big Will_'s Avatar
Big Will_
Which doesn't like sustained hard use
My oil temps were 120-125 degrees C after 2 laps of Oulton Park...
Old Oct 12, 2008 | 05:04 PM
simon170's Avatar
simon170
Hence remember to factor in its removal if your fitting a great big oil cooler, you tart
I wouldnt have a clue what the oil temps are on mine.
Old Oct 12, 2008 | 05:25 PM
Big Will_'s Avatar
Big Will_
Fear not - it's on the list
Old Oct 12, 2008 | 07:39 PM
crazycage's Avatar
crazycage
ive had a quick look on the net but the only stat i can find is the 80 degree one, would a 90 be better ? the cooler will be going where the spot lights go on a frst bumper so will get plenty cold air
Old Oct 12, 2008 | 07:44 PM
Big Will_'s Avatar
Big Will_
Speak to thinkauto/webster race and ask for a higher rating
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
