LSD box
Old Oct 11, 2008 | 10:53 PM
Ade's Avatar
Ade
Fast Ford snapper
Default LSD box
I was sure the box that went into my Mk4 was an LSD box...... it felt different in the corners, but mostly just when properly caned.
With the car jacked up the other day it was noticed that the wheels rotate in opposite directions.... the sign of an open diff. Would this happen on an LSD box which was knackered?
Also any options for sorting the LSD?
So either I've got a knackered LSD that only locks when hot/or it feels like it... or I was diddled and it never had one
Old Oct 12, 2008 | 10:16 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
a lot of poeple think that if it has a lsd that the wheels shound spin the same way in respet to the road, ie if you spin the near side counter clockwise then the of side should spin clockwise but the diff has a percentage of off lock allowing the car to turn the only true way I have found is to have the box off and look through the drive shaft slots to see the centre bar,if there is a bar then its a non lsd, if you can see straight through ith no bar then its a viscous lsd
hope this help mate
Old Oct 12, 2008 | 11:36 PM
JesseT's Avatar
JesseT
They will turn the opposite way with a resistance if a gear is selected. In neutral, they should turn freely the same way.
Old Oct 13, 2008 | 01:11 AM
brizie's Avatar
brizie
Think iv bin done over too, jacked up mine and the wheels go in different directions
Old Oct 13, 2008 | 01:29 AM
Ade's Avatar
Ade
Fast Ford snapper
Varying opinions everywhere! The internal bar seems to be the only thing people agree on........ can't really go by that without ripping the car apart though
Old Oct 13, 2008 | 07:59 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
when you have both wheels off the ground, you should feel a lot of resistance when turning one of the wheels, without an lsd, it turns freely and you'll feel virtually no resistance.
Old Oct 13, 2008 | 12:24 PM
orion88's Avatar
orion88
if u jack it up put it in neutral and turn one wheel clockwise the opposite side shoul move the same way
if they spin in opposite directions it aint lsd
thats how the lsd works putting traction thru both wheels the same direction
Old Oct 13, 2008 | 12:29 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
i had same thing.i jacked it up span a wheel and oposite wheel went different way.but wen i removed box it WAS lsd cos it didnt have the bar across.
Old Oct 13, 2008 | 12:41 PM
sas's Avatar
sas
should be good!
Go round a sharpish corner quite fast while accelerating, when the car wheelspins does it light up the inside tyre and maintaine it current curve or does it light up both tyres and understeer off the road?
S.
Old Oct 13, 2008 | 03:55 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Do a burnout?
Old Oct 13, 2008 | 04:20 PM
sm's Avatar
sm
jack the car up, get a mate to hold one wheel whilst u spin the other, if your wheel turns and your mates one dosent then it has no lsd if it turns even though hes gripping it hard then its lsd
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
