rear beam bush removal
Old Oct 11, 2008 | 10:05 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default rear beam bush removal
Whats the best way to remove them cut, burn, beat them out etc
any tips please
Old Oct 11, 2008 | 10:09 PM
blacky.'s Avatar
blacky.
if the axle is out cut the lip off the top with a saw & then use a big hammer
Old Oct 11, 2008 | 10:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's in the car:
put a jack under the beam to take the wieght
undo plate
undo big bolt
let jack down
drop beam
put big fuck off socket between beam bush and car body
jack car back up again
bush will pop out
if not, apply exess weight to car erar seat above bush
refitting
put bush into slot
apply copius ammounts of copper slip
jack bush back into beam
if stuck, again, apply extra weight via the rear seat
bush pops in no problem
Old Oct 12, 2008 | 01:19 AM
Jay,'s Avatar
Jay,
Sponsor
matt u got solid mounts ?
Old Oct 12, 2008 | 07:14 AM
blacky.'s Avatar
blacky.
i hope he has
them made a world of diffrence in the nail
Old Oct 12, 2008 | 09:05 AM
Matt Baxter
Back in black!
yeah got solid ones off b9kos
dojj that all sounds far to easy
Old Oct 12, 2008 | 10:17 AM
cossie604's Avatar
cossie604
Nah he's right, they really are easy. If your cutting the lip off then its a case of sharp shocks ie hammer to remove. If in situe just constant pressure pushing against it till it just pops clear. I remember years ago when Sierra's were common place on the roads, we had a proper tool for the job as changing the bushes happened quite often. I know this aint in your case as your using solid mounts but, I wouldnt use copper grease on rubber mounts....i'd use rubber grease (red stuff used in brake systems) insted personaly.
Old Oct 12, 2008 | 12:01 PM
Jay,'s Avatar
Jay,
Sponsor
Originally Posted by blacky.
i hope he has
yeh i hope so i gt sum goin in mine next week and gripper diff shortly so that shou;d help to
Old Oct 12, 2008 | 06:58 PM
dojj's Avatar
dojj
i'd also invest in that poly mount for the diff that mike r now can get for reasonable money
Old Oct 12, 2008 | 10:36 PM
Jay,'s Avatar
Jay,
Sponsor
are they on his website ?
Old Oct 12, 2008 | 10:39 PM
cossie604's Avatar
cossie604
Now that I deffo have to agree with...the difference one of those mounts made to mine was unreal, well worth doing even if they were double the asking price imo
Old Oct 13, 2008 | 07:58 AM
dojj's Avatar
dojj
i found them looking at a merkur site years ago, he sorted out some sort of deal to get them
unfortunatly, he knows where it is on the site but i can't find it
Old Oct 13, 2008 | 06:45 PM
Matt Baxter
Back in black!
any idea of cost
As I am well skint this month as the car is having a respray + the cost of the solid mounts ect ect it all adds up
Old Oct 13, 2008 | 07:28 PM
cossie604's Avatar
cossie604
Around £100 iirc, didnt get mine from Mike Rainbow though so dont knwo how much his are?
Oct 9, 2015 07:38 PM
atm
Sep 1, 2015 04:56 PM
Bosch
Aug 23, 2015 12:31 PM
155lee
Aug 14, 2015 11:21 AM
