People with airtec turbo coolers
Old Oct 11, 2008 | 08:52 PM
Rick's Avatar
Rick
Default People with airtec turbo coolers
Can you post up your pics of how it's fitted?
Also, how have you plumbed it?
Old Oct 11, 2008 | 09:56 PM
Smartdj.'s Avatar
Smartdj.
iv asked this question atleast 3 times and it turns out were the only ones with them..if you do get a reply be sure to send it to me!!
Old Oct 11, 2008 | 10:22 PM
Rick's Avatar
Rick
Mine is in, but it's not a stock install as i have a single pass cooler and my rad is moved back. Just wanted to see what others had done.
Old Oct 11, 2008 | 11:24 PM
project rs's Avatar
project rs
mines currently sitting behind the passenger headlight sitting on craddle while i await my change to efi then when i get extra space i'll find somewhere it gets a nice air flow, buy way rick how is car coming and if you want a picture let me know and i'll post some up for you
Old Oct 11, 2008 | 11:40 PM
dave_y's Avatar
dave_y
mine is fitted pretty much where the standard intercooler would normally sit. I have a GRS intercooler at the front then an airtec alloy rad behind it with the airtec turbo rad sitting next to it. It is plumbed in between turbo and radiator. So water comes out turbo through turbo rad into radiator.
Can take a photo tomorrow for you when its daylight out
Old Oct 11, 2008 | 11:58 PM
Rick's Avatar
Rick
ive moved mine as much behind headlight as possible. its held in by tie wraps lol. simply because it's the best way. im going to have to take some data logs when the car goes on the road to watch the inlet temps, as the filter is behind the cooler. i did some maths earlier and it should have minimal effect on inlet temps apart from on idle where thje map will compensate anyway.
dave y - would be interested in pics mate
Rich - ive been ill after holiday, then away with work so it's not going well! Hoping from now on i have some time. Im just enjoying blipping the throttle at the moment as it's sooooo responsive..
Old Oct 12, 2008 | 07:45 PM
dave_y's Avatar
dave_y
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
muz
Aug 16, 2015 12:57 PM
