r reg mondeo 2.0 location of fuel pump .
Old Oct 11, 2008 | 09:45 AM
mick320BHP's Avatar
mick320BHP
Question r reg mondeo 2.0 location of fuel pump .
as above cheers mick
Old Oct 11, 2008 | 09:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if you are unlucky, it'll be in the fuel tank
if you are even more unlucky and decide to do this swap on a mk3 mondeo, pay someone a fixed sum of money to do it
Old Oct 11, 2008 | 09:51 AM
mick320BHP's Avatar
mick320BHP
cheers
Old Oct 11, 2008 | 09:53 AM
dojj's Avatar
dojj
if the tank in centrally mounted, you may be able to wiggle it out via the hole in the bottom of the seat base, just remove the rear bench and you should be ale to see it
but on the mk, you've got to drop the exhaust and move a bit of the rear suspension because the hole is about an inch too small to get the pump out of
Old Oct 11, 2008 | 10:07 AM
RichieST's Avatar
RichieST
He said R reg dojj, so that will be mk2. If you lift the back seat up, there should be a cover plate. Revove this, and you should see the pump in the top of the tank
Old Oct 11, 2008 | 10:29 AM
craigos's Avatar
craigos
dunt the fuel pump have a trip switch?have you tried that?
Old Oct 11, 2008 | 11:50 AM
dojj's Avatar
dojj
i know what he said but if it's anythinglike the mk3 where ford decided to make the hole offset so that you could see the bits you need to see but still have to have a struggle to get the tank out etc he might not be in luck
in that case take a can opener to the seat base and do it that way, it's only a twist and click pump from memory
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
