Steel Rods and ARP bolts
Old Nov 12, 2004 | 11:03 AM
zvhturbo's Avatar
zvhturbo
Default Steel Rods and ARP bolts
Do you tourqe the ARP con rod bolts up the same as the Haynes manual says for stanard type bolts??
It says:
Stage 1: 13LB/Ft
Stage 2, 90 degree turn.
This is for a 2.0 zetec.
Matt.
Old Nov 12, 2004 | 11:08 AM
Garage19's Avatar
Garage19
Sorry to hijack your thread, but i have a set of new zetec ARP rod bolts that I don't need any more. Cost Ł82.50 from Burtons but I will let them go for Ł60 if anyone is interested?
Old Nov 12, 2004 | 11:09 AM
CabrioTurbo's Avatar
CabrioTurbo
i dont know if it the same for a zetec as a CVH but the settings for mine were not the same as the haynes manual.
Old Nov 12, 2004 | 01:51 PM
zvhturbo's Avatar
zvhturbo
Old Nov 12, 2004 | 03:04 PM
xr4x4rs's Avatar
xr4x4rs
on my instructions for arp for the cossie bolts
it says do not use manufactures settings only what arp supply which is 80nm
if thats any help m8
Old Nov 12, 2004 | 03:54 PM
Rick's Avatar
Rick
different on cvh
Old Nov 12, 2004 | 04:44 PM
nthorpey's Avatar
nthorpey
Phone burton as they supply them and should now or ARP themselves will be able to tell you.
Old Nov 12, 2004 | 07:53 PM
AndyRST's Avatar
AndyRST
only go by the ARP ratings AFAIK
Matt you got the piston clips now then ?
Old Nov 12, 2004 | 08:24 PM
Moose 130's Avatar
Moose 130
I thought ARP go by 'stretch' and not torque settings?
here is thier PDF file from thier web site www.arp-bolts.com
http://www.arp-bolts.com/pages/tech/images/rod_bolt.pdf
Maybe your part number can be cross referenced.
Old Nov 12, 2004 | 08:30 PM
Moose 130's Avatar
Moose 130
Infact they show for a 2.0 zetec with a 9mm rod bolt a torque of 36ft/lb with thier lubricant which has a stretch of 0.0049 inch.
1.8 zetec with a 8mm bolt 26ft/lb and 0.0050 inch. stretch
always use thier lube with thier fasteners
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
