escort horn problem
Old Oct 9, 2008 | 05:01 PM
linux44's Avatar
linux44
Unhappy escort horn problem
hi
I have escort 1.6 zetec 1996 and the horn is sometimes working and sometimes not
I did open the 2 bolt on back of steering wheel to take out the airbag so the cover on the steering wheel is open but could not find anything that seems to be faulty
any idea?
Old Oct 9, 2008 | 06:09 PM
dazoriginal's Avatar
dazoriginal
prodigal son
try cleaning the connections
Old Oct 10, 2008 | 11:05 PM
linux44's Avatar
linux44
Unhappy
where are those connection
let me tell u one thing ,the horn was working properly till one day i was board and pull the steering wheel toward my self couple of time from that time that happen to it and at the moment it is not working at all
please help as i need to renew my mot next month
Old Oct 11, 2008 | 06:52 AM
Look at the slip ring on the back of the steering wheel to see if it dirty or worn.
Old Oct 11, 2008 | 06:58 AM
fraser9764's Avatar
fraser9764
that would be my guess, i had one that used to make a grinding noise when i turned the wheel, one of those annoying noises, must have been dry for a while and somehow started to wear a grove into the back of the steering wheel, used some silicone grease and its been spot on since. this was on a subaru justy btw but i can only assume escorts will be the same idea
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
