Norton Firewall - Trojan Horse matched?
I keep getting a warning coming up on my PC from Norton Firewall telling me its blocked an attempt to hack my PC...
Security alert - High risk
Attempted to connect to local computer using the NetBus Trojan horse blocked...
This happens about once an hour, I've run both my anti virus programs and they haven't picked anything up, just about to run Spybot and see if that finds anything, but other than that I'm lost...
Anyone got any ideas?
This can be an attempt by your isp to check you are still online and is not necerserally an attack.
check the i.p address and post here and i can tell you who it is.
most hackers these days wouldnt use this type of atack as it leaves an ip which is tracable.
My router's firewall blocks NetBus scans all the time......basically, it's either an already-infected machine scanning for other machines to infect, or a "central" server looking for already-infected machines to remote-control them.
If your firewall is blocking them, you can either ignore them or you can grab the IP, identify the culprit using something like the third box down in the middle column (assuming it's working now), and report them to their ISP.
Fookin hell a different one now....
Attempt to connect to local computer using the Back Orifice Trojan horse blocked
Time: 16:58
Date: 13/11/2004
Protocol: TCP (Inbound)
Remote Address: 80.41.103.205 : 2720
Time: 16:58
Date: 13/11/2004
Looks malicious to me now.
Server Used: [ whois.ripe.net ]
80.41.103.205 = [ ] This is the RIPE Whois tertiary server.
The objects are in RPSL format.
Rights restricted by copyright.
See http://www.ripe.net/db/copyright.html
inetnum: 80.40.0.0 - 80.47.255.255
org: ORG-TUL3-RIPE
netname: UK-TELINCO-20011123
descr: PROVIDER Local Registry
country: GB
tech-c: TU935-RIPE
admin-c: TU935-RIPE
status: ALLOCATED PA
notify: hostmaster@uk.tiscali.com
trouble: Information: http://www.tiscali.com
trouble: Concerning abuse and spam ... mailto: abuse@uk.tiscali.com
Forward that exact log to the above bold-highlighted address...
org: ORG-TUL3-RIPE
country: GB
tech-c: TU935-RIPE
admin-c: TU935-RIPE
Back Orifice trojan-horse, if it works like most other trojans, will just scan a range of IP addresses set by the trojan, for vulnerable machines to which it can spread itself......I doubt what's happened is a manual-attack, more a case of an infected machine automatically trying to spread the trojan to other vulnerable machines.
Report it, all the same, though...
This type is malicious though and is used to look for open ports, it will tell people scanning of open ports in a range and give them entry.
I`m not saying this is the case as it also is a spread virus like mentioned above.
A port-scan would show up slightly differently to a firewall that's blocking it, though, you'd get LOTS of entries or pop-up windows to show you of the activity hitting sequential ports...
Not saying that the activity noted above isn't a manual attack, but from experience of dealing with this kind of thing in work, it's "normally" the trojan trying to spread itself automatically......you'll probably find, in 99 out of 100 cases, that the person whose computer it is doesn't even know their own computer is doing it.
Also, port-scans tend to go for the more "popular" ports, like 25 (SMTP), 21 (FTP), telnet (23), and so on, as they're more easily abused by someone who knows what to do with them.
the more I block the more try to attack....
Time: 22:55
Date: 13/11/2004
Remote Address: 80.108.113.16 : 3052
Local Address: 80.41.212.224 : 27374 (I forgot this bit last time)
The only thing I was logged into was messenger, so it looks like its trying to spread itself through there....
Time: 22:55
Date: 13/11/2004
