General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
don't know how the V6 is mounted, but on a normal cossie they are a peice of piss, just lift the engine up once you undone the nuts top and bottom of the mount and they come in an out dead easy 2 hrs at an absolute max
you no listen!!!! gen ford ones are total shit, my engine moves horrendously
dunno about a thumper jim but easiest way to change them on a 3 door is to support the engine with a trolley jack and undo the hangers from the block cos you cannot lift the engine high enough to get over the engine mount top thread even with the bell housing pressed against the transmission tunnel, well i did manage it like but i have an engine crane at the time, only afterwards the remove hanger method was recommended
Yep, that's how I did it. Unfortunately, I forgot to undo the opposite mount when jacking the engine up to change the fucked one, so now have one vibratechnics and one fucked ford mount
