MK3 & MK4 Escort doors!?
Old Nov 12, 2004 | 08:05 AM
B19-TRB's Avatar
B19-TRB
Default MK3 & MK4 Escort doors!?
If ur not worried about doors cards lining up r the doors on a mk3 escort the same as a mk4!? i.e. will mk3 doors fit mk4 car!?
also will mk4 mirrors fit mk3 door!?
Old Nov 12, 2004 | 08:11 AM
gingeRS's Avatar
gingeRS
spose so. the only differences are internal. mirrors should fit too
Old Nov 12, 2004 | 08:13 AM
Wazzzer's Avatar
Wazzzer
Yes they are exactly the same, the Mk4 door even has the hole on the inside for the push down lock like the Mk3 has
Old Nov 12, 2004 | 08:17 AM
B19-TRB's Avatar
B19-TRB
excellent!
Old Nov 12, 2004 | 09:27 AM
BillyCabrio's Avatar
BillyCabrio
Yeah it's just the inner door skins that are different.
Old Nov 12, 2004 | 09:33 AM
Ryan's Avatar
Ryan
whole door is different
but they will swap over.
Old Nov 12, 2004 | 09:37 AM
B19-TRB's Avatar
B19-TRB
Ryan what needs to be done then to make em fit!?
also when u ay whole dorr is different do u mena like the swage marks!? i.e. the door will look odd on amk4 shell!? & also will mirrors fit!?
Old Nov 12, 2004 | 10:54 AM
JesseT's Avatar
JesseT
Only major concern is the hole size for the lock which is larger on a mk4. So fitting a mk4 door to a mk3 needs some fiddling around if you want to use the original locks.
Old Nov 12, 2004 | 11:02 AM
B19-TRB's Avatar
B19-TRB
well am fiittin a mk3 door to a mk 4 shell & they will b de-locked any how!
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
djmca
Aug 20, 2015 08:26 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
