2wd Cosworth breaking - moonstone blue
Right maybe selling breaking my car now as the current stature of things means all these cars seem to be worth more money in bits than as a complete package. The minimum price for the whole thing is £5k as i know it will split for this with ease. However I would want the engine to be sold first. Can deliver and will be as helpful as possible. So if your genuinelly interested or want something try me, ideally the engine first.
engine - head + bottom end with inlet manifold and grey injectors - £3000
-touring car style ported and bench flowed head for 500bhp +
-Nikasil liners
-wire rung block
-isky valve springs
-bd10 and bd14 camshafts
-piper vernier timing pulleys
-new core plugs
-inline oil filter with aeroquip hosing as there no mounting on the block for the oil filter, so it must be fitted via aeroquip piping and is currently mounted on strut brace.
-triple layer wrc metal headgasket
-all new gaskets and seals which are by cometic from burton power
-low comp 7:2:1 compression ratio pistons with valve cut outs
-knife edge and polished crank with lightened and balanced of complete bottom end
-new shot peened rods
-burton high pressure oil pump
-long studded
-ap 6 paddle clutch kit
-The block is 12lb's lighter or so than the standard 200 block and is a genuine cosworth WRC block
car-
- secs engine monitor £200
- 4inch mongoose system £150
-T35 turbo .63 exhaust housing good for 450bhp with -31 and manifold £300
- brembo 330mm big drilled front brakes and red bells £500
- 044 group a fuel pump £60
- stage3 L6 setup ecu with chip/803 greens/bar map sensor £250
- rs500 intercooler radtec £200
- 17 x 8 compomotive mo wheels in white 205/40/17 excellant tread £700
- front and rear strut braces £100 pair
- 3 gauges in car oil pressure,oil temp, boost gauge £50
- samcos water and boost in red £125
- leather recaro interior £200
- bailey water swirl pot £50
- forge dump valve £40
- t5 2wd gearbox £250
- rolling shell g reg 7 owners, leda coilovers, lsd diff, f&r bumpers all panels, dash & 4x4 bonnet, engine bay loom, spare white tailagte, leather interior £1500 without leather £1300
please let me know on all genuine interest
-Nikasil liners
-wire rung block
-isky valve springs
-new core plugs
-long studded
car-
I need the following please:-
1x rubber engine mount
door panel screws
metal water pipe at bottom of rad
fan switch plug with about 2" of wire left on
rad mounts
circlip that holds the speedo cable to gearbox
both front kick plates
how much with postage to bristol please
door panel screws
rad mounts
i'm interested in the full car, can you answer these question please mate?
who built the engine?
any receipts for the build?
are you sure it has nikasil liners as well as been wire rung?? i was told you don't do both?
everything is on hold folks at the min as i have potenetial buyers for the whole thing now, well theres 3 interested parties. Anyone else want to view pm me. Price is 5k firm to passionford users.
cheeRS
cheeRS
roosie pm me with what u were thinking, but ideally need to get something newer like an x5 3.0 d or something, main reason i'm cashing the cossie in unfortunately
cheeRS
cheeRS
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
pics?
