2wd Cossie Engine Undertray ???
Old Nov 11, 2004 | 10:16 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 2wd Cossie Engine Undertray ???
My 4x4 cos has a great big sheet of plastic which runs from both front chassis rails and up to the front bumper. Was this an addition to the 4x4's or did 2wd ones have them too ?
Will a 4x4 one fit on a 2wd ?
Only asking cos our 2wd doesn't have one
Thanks in advance
Greg
Old Nov 12, 2004 | 06:51 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i got one off ebay which the seller said was from a 4x4. it fitted fine onto my car, which is a 4x4 shell with 2wd running gear. dunno if the 2wd shell has the captive nts in the chassis rails? anyway, it clears the 2wd crossmember and everything.
little tip for you - to fix it on, don't use bolts cos they're way too fiddly. screw some studding into the chassis rails and then the tray just pops on them and holds itself in place while you put some nuts on.
Old Nov 12, 2004 | 07:07 AM
The rwd does not have the captive nuts to fit the undertray, my chassis has been drilled & the captive nuts fitted so i can use an undertray.
Rod
Old Nov 12, 2004 | 07:24 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
My Sapphire (one of the last 2wds made) had the captive nuts in place, so it just bolted straight up....
The item is no longer available from Ford, so would have to be purchsed second hand.
Old Nov 12, 2004 | 07:54 AM
frog's Avatar
frog
Thanks guys, my saff's E reg so chances are the captive nuts aren't there unlike Mike's.
Good tip mr ForeignRS... will remember that next time I take my 4x4 one off.
Rod, I hope your undertray is a little more than a sheet of thick plastic
Old Nov 12, 2004 | 01:36 PM
Its a hybrid one , parts of it are orginal but the fixings & Front section have been modified in ally & shape changed to help airflow.
Cheers Rod
Old Nov 12, 2004 | 01:55 PM
foreigneRS's Avatar
foreigneRS
Testing the future
any pics rod? sounds interesting. do you run a complete undertray, or just front?
Old Nov 12, 2004 | 02:13 PM
Spiky's Avatar
Spiky
i have a really thick KEVLA undertray
will get pics next week
Old Nov 12, 2004 | 02:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i guess your undertray is for protection rather than any aerodynamic benefits spiky. will still be cool to see some pics
is it me, or does anyone else chuckle at the word 'undertay'?
Old Nov 12, 2004 | 03:38 PM
frog's Avatar
frog
Great idea - let's see some pics of bling undertrays...
Er, no.... Dunno what else to call them either (underskirt ).
Old Nov 13, 2004 | 10:38 AM
foreigneRS's Avatar
foreigneRS
Testing the future
here's pictures of my undertray. just a std 4x4 one on a 2wd converted 4x4 shell
from front
from back
rear fixing stud
front fixing stud
Toe Knee
Aug 23, 2015 08:31 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
