OFAB / XR2i loom question
Hello
I've got a few questions for ya!
I'm busy with a FRST, with OFAC managment. But the loom is terrible.
Now i have put in a complete loom from an XR2i, 1.6 8V. Can I just connect for example an OFAB engine loom with the multiplug from the XR2i loom?
I think so, but not sure?
Many thnx
Berry
Many thnx
Berry
Allright,that's nice to know.
But when I connect it togheter, then I shouldnt have to rewire the loom or something else?
I think that it would work, the FRST and XR2i interior-loom looks the same.
It runs !!!
But few little problems,
it idle's very bad...from 500 RPM till 1300 RPM.... could this be valve on the left side from in inlet-manifold? Idle control valve?
And another question, when I pull the throttle, it takes a little times before the engine revs...
It seems like, he needs a few milli-seconds to think.
What could this be? I've allready replaced the CPS, but no result...I haven't drove it jet, could the be the cause? Maybe if I take it for a spin it's solved?
muz
Sep 30, 2015 08:29 AM
