cossie PAS tank pressure
Old Oct 7, 2008 | 04:14 PM
sortedsaff's Avatar
sortedsaff
Default cossie PAS tank pressure
im in need of a PAS tank for my 2wd cossie was wondering what sort of pressure the whole PAS system has as was thinking about using a different type of tank for it (like and small typre header tank from a different car)but want to make sure it can cope with the pressure.
CheeRS
Tony
Old Oct 7, 2008 | 05:14 PM
The tank itself is not under pressure, it serves to fill the pump and as a return for the fluid that is pushed through the rack when operating, but the actual tank is vented to the air.
Old Oct 7, 2008 | 05:35 PM
sortedsaff's Avatar
sortedsaff
ah thats sweet thanks for the reply .i take it as there is no tank on it at the mo when i fit one i wont need to bleed it or anything?
regards
Tony
Old Oct 8, 2008 | 04:46 AM
There is a bleed sequence but I have never found it needed on a cossie, so should be ok.
jonfoc
16
Sep 11, 2018 05:35 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Dubs44
Sep 19, 2015 06:31 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
