how can i upgrade the viscous coupling on the MT75
the viscous contains a fluid, you make this fluid thicker, the viscous gets tighter
you would need to remove it from the vehicle though, unless bernie from gearboxman will be able to sell you one already pumped up and you can get someone to fit it for you
if you are handy with the spanners it's not a massive job to remove the rear prop, remove the rear casing of the transfer box and swap the units over
as for pics, i did a thread a while ago about how to change the bits and bobs over, if you can find someone who can help you locate it it should all be pretty self explanatory
