RS Turbo Radiator?
Old Oct 5, 2008 | 05:53 PM
mikey_clough's Avatar
mikey_clough
Default RS Turbo Radiator?
does anyone know if mk4 xr3i radiators and mk4 rs turbo radiators are the same? i would of thought they are but its always good to check. cheers
Old Oct 5, 2008 | 05:56 PM
L3 COS's Avatar
L3 COS
the size is the same,only difference being the fans on the back(exhaust manifold side) on a xr3i and on a turbo its on the front because the turbo,s in the way,so the difference is the brackets! including the ones on the right side,a turbo has extra lugs on series2 for the intercooler!
Old Oct 5, 2008 | 05:59 PM
mikey_clough
i have a pace intercooler in front of the rad so the fans are on the intercooler, do i have to worry about the brakets for the rad then?
Old Oct 5, 2008 | 06:00 PM
jacko's Avatar
jacko
they aint the same length mate the 3i is longer and the intercooler pipes wont go through the gap
Old Oct 5, 2008 | 06:05 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
they couldnt be more different!like jacko said,there smaller,fatter and u wont fit ya cooler pipes thru
Old Oct 5, 2008 | 06:08 PM
mikey_clough
ok, cheers, ill have to start lookin again for another one.
Old Oct 5, 2008 | 07:12 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i have a few
Old Oct 5, 2008 | 08:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah like everyone says they couldnt be more different! Much shorter allowing for the intercooler to sit beside it.
Old Oct 6, 2008 | 07:37 PM
slimwynn's Avatar
slimwynn
u have also got an extra pipe from the turbo to the rad
Old Dec 29, 2018 | 08:20 AM
simonmcf's Avatar
simonmcf
An old thread to dig up!
converted mfi to efi - I believe I have a XR3i loom. Should the Rs Turbo fan plug fit directly into the loom? I seem to have located the loom plug but it won’t fit?
yatta
May 21, 2016 10:31 PM
RSBryden
Sep 6, 2015 08:39 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
