anyone got a good bottom end
does anyone have a good 200block with low comp pistons etc already done lying about in there garage or summit, need a good block with low comp etc,goin to be on greys so need to be std size or .25 as ive got a200, .5 overbored block but have been told that i need it reboring to 1mm over and that the block will be no good for 380ish as it will be too weak?
can you pm details and price please
cheers
cheers
Carl
I have a brand new built not even run
200 blocked bottom end
200 block
All balanced
New mahle pistons ( low comp 7.4.1 ) and pocketed
0.25 reground crank
All gen cosworth shells / oil pump etc etc
all built up and ready to fit
lightened flywheel
It also has a 2wd head fitted , rebuilt / ported . if req, but i will remove it
200 block
All balanced
0.25 reground crank
lightened flywheel
good one pete
mine can be supplied with a 4x4 head also if require. All needs build but that way you know its put together right as buying a build engine from someone other than a legit tuner you'll have no come back with probs etc.
mine can be supplied with a 4x4 head also if require. All needs build but that way you know its put together right as buying a build engine from someone other than a legit tuner you'll have no come back with probs etc. Thread
borboyous
Aug 22, 2015 11:17 AM
