saff aerial lead where it go??
Old Nov 11, 2004 | 04:21 PM
DOO's Avatar
DOO
Default saff aerial lead where it go??
Getting some paint work done on the saff and i am removeing an aerial some ones fitted on the rear wing
someone has cut the aerial lead to fit the shoonky aerial on the back wing.
Now it`s not long enough to go to radio amp on the rear parcel shelf got a new aerial lead(from radio to amp back window) where does it run under the carpet or in the roof lineing?
Old Nov 11, 2004 | 04:47 PM
cossiestu's Avatar
cossiestu
Not positive, but i think i saw an aerial size wire run along the N/S sill, when i last had the interior out...
HTH
Old Nov 11, 2004 | 04:52 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Thought it run along the headlining
Old Nov 11, 2004 | 05:42 PM
DOO's Avatar
DOO
anymore i thought it went behind the roof lining but not sure??
Old Nov 12, 2004 | 06:58 AM
foreigneRS's Avatar
foreigneRS
Testing the future
for definite it goes up the a-pillar, along the roof and back down the c-pillar - between the metal panels.
doesn't necessarily have to though.
Old Nov 12, 2004 | 08:17 AM
DOO's Avatar
DOO
Don`t fancy fooking about with the roof lineing.I think i will try along the sill 1st if long enough. If not roof line it will have to be
Old Nov 12, 2004 | 08:28 AM
foreigneRS's Avatar
foreigneRS
Testing the future
roof lining is not that difficult to remove and get back properly, particularly just on one side. the fabric is glued to a card panel and you just remove the door seal and the a,b and c pillar trims and maybe the sunroof rubber, and the jesus handles and the sun visor.
wouldn't do it if your car is mint and you want to keep it that way though
Old Nov 12, 2004 | 08:57 AM
CraigN's Avatar
CraigN
up the apillar and inbetween pillars and roof skin the down c pillar and to the rear windscreen
i replaced mine when i reshelled
easy to remove not so easy to get back in as it goes inside pannels were you cant get to
Old Nov 12, 2004 | 08:59 AM
DOO's Avatar
DOO
Cheers mate i think i try it along the seal 1st.
Don`t really want to remove the roof lining as it`s mint.knowing my luck it won`t fit back correctley
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
The Youth.
Sep 30, 2015 09:59 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
