temporary way of turning boost down
Old Nov 11, 2004 | 03:58 PM
Paul_RS's Avatar
Paul_RS
Default temporary way of turning boost down
is there any way to do this easily on an ERST? I'm asking as mine is going into a bodyshop soon to get the engine bay done, but i'd didn't like the look of some of the wee spides about giving all "Is that one of o dem der turbos leek? does it have a dump vale?"
Oh my car is running the amal valve and not a bleed valve if that helps?
Old Nov 11, 2004 | 04:02 PM
Jim Galbally's Avatar
Jim Galbally
pull the plug off the amal valve for low boost
or for zero(ish) boost pull the arm on the actuator off of the wastegate
Old Nov 11, 2004 | 04:03 PM
Filthy Rich's Avatar
Filthy Rich
Disconnect the amal valve mate
Paul_RS's Avatar
Paul_RS
cheers jim, i'll prob do the amal valve as i can't be arsed trying to pull the arm off the actuator!
Old Nov 11, 2004 | 04:29 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
arm off the actuator is a piece of piss and thiss will knock the boost right off
Old Nov 11, 2004 | 04:46 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
amal will still give low boost and enough for thm pikey lil shits to think its fast as fuck and go ramping the bollocks out if it.
lil fuckers like that at 90% of garages/bodyshops is why im always VERY careful where i take my car
Old Nov 11, 2004 | 05:10 PM
bigmatt-s2rst
i do all the work on my car for that reason, cant trust anyone!!! my mate has his own unit with a ramp so i can get down there any time, i had my car sprayed recently by a friend, but i still put it in with next to fuck all petrol in it, lol
Old Nov 11, 2004 | 05:30 PM
Oranoco's Avatar
Oranoco
As Jim says take the actuator off the wastegae. Also note the mileage before dropping it in.
Old Nov 11, 2004 | 05:38 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
I went to a cruise with a mate one time and this lad had turned up in a customer's CRX del sol!
Old Nov 11, 2004 | 05:39 PM
ballin's Avatar
ballin
in all honesty mate, i dont think they will drive it.
the company wouldnt due to legal reasons, insurance reasons and simply wouldnt want the risk of paying out damages as well as petrol/mileage etc
Old Nov 11, 2004 | 06:56 PM
Paul_RS's Avatar
Paul_RS
disconnected the amal valve and i stills boosts as usual What does this mean? that the amal valve is buggered?
Old Nov 11, 2004 | 07:11 PM
Jim Galbally
that the amal is doing feck all... lol
when was it last setup? who set it up? and has it always held the same boost it does now?
Old Nov 11, 2004 | 07:14 PM
Paul_RS's Avatar
Paul_RS
was setup a couple of months ago, by a guy called Ciaran Killen. I has always held similar boost, but when i first got the car it had a bleed valve which he removed. Only thing is i took the turbo off a while ago and i'm not too sure if i put the amal vile pies on the correct way. I've just been out and tried changing them about, but it makes no difference. Oh yes i am a numpty for messing with it
Old Nov 11, 2004 | 07:16 PM
rsrob's Avatar
rsrob
a few years ago 1 of my mates had his 4x4 cossie pas him @ about 100 mph on the motorway when he went in to confront the garage they said they were test driving it
dont think he went back there again
Old Nov 11, 2004 | 07:17 PM
Jim Galbally
C= turbo
W=Actuator
R= Airbox
its likely you put them on the wrong way yes
wen the amal plugged in does it "click" when you turn on the ignition?
Old Nov 11, 2004 | 07:20 PM
Stu.H's Avatar
Stu.H
take the battery and ecu out of car and get em to push the cnut about
Paul_RS's Avatar
Paul_RS
yep, there is a click from under the bonnet. unfortunatly there is nobody else with me so i can get them to turn on the ignition so i can hear where the click is from! I'll go and check the tubing now, cheers again jim!
This guys in N.Ireland, you sure its the same place? no motorways for miles round his place.
Old Nov 11, 2004 | 07:33 PM
Paul_RS's Avatar
Paul_RS
ok went and had a look there, cant see C W or R makings on the amal valve? well i know the on to the metering head is right as it was never disconnected. The top hose goes to the turbo and the middle goes to the actator. That sound correct?
Old Nov 11, 2004 | 07:35 PM
Jim Galbally
i dont know, stu told us once but ive forgotten
easier way... turn ignition on, plug in and unplug amal valve... does it click now?
Old Nov 11, 2004 | 07:40 PM
Paul_RS's Avatar
Paul_RS
its working ok, there is a click when its plugged in, no click when its unplugged.
Old Nov 11, 2004 | 07:43 PM
DazC's Avatar
DazC
To stop them driving it, just do what Jim does...plug the chip in the wrong way round...Unfortunately it will also stop you from driving it!!!
Sorry Jim!
Old Nov 11, 2004 | 07:48 PM
Paul_RS's Avatar
Paul_RS
lol! maybe if i have a word with the owner - he's an older guy who seemed to know a bit about RS's he'll not let anyone drive it...
@might be because my car is only running 14psi that i dont notice any difference when i unplug the amal valve?
Old Nov 11, 2004 | 09:08 PM
Jim Galbally
the difference between 14psi and with the amal unplugged should be more than noticeable!
if the amal clicks, its working
if it makes zero difference to the boost the car produces, i suspect that either the amal valve is shagged, or youve got it plumbed in thw wrong way round...
and daz... you coooooont
Old Nov 11, 2004 | 09:38 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Jim, it EVER occur to you that the 14psi is set on the actuator and not the amal?
Uprated actuators are usualy 1bar spring
And trust me, customer cars get ragged a LOT by most companys workers given half a chance, i used to at Honda
Old Nov 11, 2004 | 09:43 PM
Azrael's Avatar
Azrael
Take out the ECU
Old Nov 11, 2004 | 10:15 PM
xr-stu's Avatar
xr-stu
loosen all the boost pipes so it wont hold boost, and will drive like wank! thats the easiest way i recon mate
Old Nov 11, 2004 | 11:06 PM
Paul_RS's Avatar
Paul_RS
the boost is set by the actuator soryy don't know enough to realise that was important! take it thats why the boost wont turn down then?
Old Nov 12, 2004 | 01:42 AM
RSBen's Avatar
RSBen
No! Swap them round, top one goes to actuator, middle one goes to turbo.
Old Nov 12, 2004 | 06:25 AM
Paul_RS's Avatar
Paul_RS
cool, i'll do thank Ben. Cheers!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Russ Payne
Sep 25, 2015 08:29 PM
