fitting plenum spacer
Old Oct 3, 2008 | 08:17 AM
proboscus's Avatar
proboscus
Default fitting plenum spacer
i have fitted a 10mm plenum spacer to my 4x4 sapph.when refitting the fuel rail i have bolted it to the rear of the lugs on the cover that it originally bolted to as if i had put it back as it was originally it would not reach the injector heads.was i correct in doing this or is there another way of refitting the fuel rail.
Old Oct 3, 2008 | 10:19 PM
Simmo's Avatar
Simmo
The 15mm spacer can sit on the other side of the lug fine... but the 10mm spacers normally require the lugs to be cut/ground back so the injectors sit at the correct angle...
Oct 9, 2015 07:38 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 20, 2015 09:21 PM
markk
18
Aug 17, 2015 05:19 AM
Aug 14, 2015 07:29 AM
