Converting Cue/Bin files to Mpeg/Avi?
a cue and bin file is an image of a cd
its basically a recording of a cd onto a hard disk and compressed into one file instead of copying one cd to another
you need to either burn the file to a cd to get it back to its original state or use something like daemon tools to open the image file
the small file (CUE) is jsut text that has the track at once info relating to the BIN file
they have to both be in the same file to work
and you have a problem if you have a bin file but no cue file
Smit, easiest way round this is the following:
1) Open Nero Burning Rom 6
2) Click on recorder on the top, then click on choose recorder
3) Choose Image Recorder
4) Click recorder, then burn image
5) Access the cue file you want to burn, it will then load it, then ask you where you want to save the file.
6) Once burnt, click start -> programs -> nero -> nero imagedrive and then enable both image drives, these will appear in my computer as extra dvd drives.
7) Rick click on the newly created image file of the cue file, and then left click on Imagedrive and then you have accessed the file
The 60ft Launch King
Cheers Dan
But got that daemon thingy and i've done it..piece of piss program to use!
Jim - cheers buddy was in the folder that u said it would be...roll on the DVD i say
you now need to convert that mpeg into DVD format to play it on a DVD player tho tho
i normally use a program called "winavi" to do this, but for some reason it doesnt like VCD style mpegs as input sources
so i have to use nerovision express... takes a few hrs to convert, but once its all sorted it'll work fine.
ps you should be able to play VCDs ona DVD player... just burn the thing in nero... most DVD players will happily play these, so you dont HAVE to convert it to DVD format
Jim i've done that mate
Ulead dvd factory does the hard work...so i don't have to!
started to watch it on me DVD player while i'm finishing up n here
