Computer people help urgent please
Old Oct 2, 2008 | 01:07 PM
slowpoke's Avatar
slowpoke
Default Computer people help urgent please
right my laptop, an eacer has the HD set in two partitions ie c and d drive,
c drive is only 10gb so gets very full very quickly, so i want to remove the partition so its one big drive,
i just put the recovery cd in and its just redoing the partition ie not asking me if i want it all in one,
how can i remove the partition ?
the thing thats running now is a acer recovery tool by symantec and not microsoft windows re installer
help lol...................Matt
Old Oct 2, 2008 | 01:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
just save the stuff on the D drive mate, much easier
unless the c drive is the basic boot up bit like most new computers i've seen have, just there to help aid recovery of the system should it go tits up
i'm sure you can move partitions and copy stuff over, but youwold need a proper computer type person to make sure eveything was right or it'll fuck shit up in a big way
Old Oct 2, 2008 | 01:23 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Right-click on 'My Documents' and move it to D: in the options.
That way you have all your personal stuff, MP3s etc.. on D: and all your software on C: thus balancing it out a bit better.
It also gives you a better 'failsafe' as C: is far more likely to be corrupted or suffer hardware failures than D: due to the frequency of use.
Old Oct 2, 2008 | 01:49 PM
_SpeedX_'s Avatar
_SpeedX_
if your not offait with computers i wouldnt really attempt making changes to the partition.
if you want to attempt it you could try partition magic as thats a basic prog, however there are alot better products that do the same..
Old Oct 2, 2008 | 01:59 PM
tsutton's Avatar
tsutton
It doesn't make any difference based on amount of usage - it's still on the same drive!
If the HDD dies, BOTH partitions will die with it!
If you want a proper failsafe, get two HDDs. One as drive C and another HDD as drive D. And a decent backup software.
Old Oct 2, 2008 | 02:02 PM
dunketh's Avatar
dunketh
Doh!
I'm so used to running multiple drives I completely missed this obvious fact.
Anyway, moving 'My Docs' will still help the problem, if not affording you any more safety.
Old Oct 2, 2008 | 02:18 PM
FasterFords's Avatar
FasterFords
How large is the D partition ?
Old Oct 2, 2008 | 02:35 PM
collierm's Avatar
collierm
MP for K.I.S.S
There is a free utility called GParted you can use. Burn the ISO image to a CD, reboot and then you can manipulate the logical drives so you have one massive C partition. Its also non data destructive so you won't lose anything.
Partition Magic does the same job, but its not free.
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
rsguy
44
Sep 29, 2015 03:29 PM
